DMedina559
And any thing added or removed from the /system parton (flash any tweaks or removed system apps etc) would have to be done again.
(unless you don't want them anymore)
Nothing worked to fix the silent ringing problem, so I moved to AOKP. The last version of AOKP had the same problem, but the ringing problem seems to be gone with the 10-3 AOKP update, or at least I haven't been able to reproduce it since upgrading.Unfortunately, neither factory-resetting the phone nor applying the patch worked. The first call after reboot is still silent, as are random calls during the day.
I only re-installed apps I can not function without, so I guess my next step is to eliminate all apps and see if it fixes the problem. Beyond that, I give up.
He got the phone the day it came out and it still works great, surprisingly lol. After updating to the 10-3 build, I noticed that I could not connect to the play store, MMS is still broken, and the WiFi indicator was stuck to a white color, although I could connect to all other services that I tried. I was previously using (I think) the 8-23 build. I anxiously await a fix... Has anyone else had these problems? Sorry if there is already a fix for this, I haven't had time to search through. Also, the video camera was fixed for me. Not all bad news!
Are you going to fix cm10 it is the best out of the most of the roms.
Im running the cm9 rom and i cant get it ring when i get phone calls it will only vibrate. would like to be able to hear phones when they come in. Please fix. Phone LG Optimus Elite![]()
Yeah I'm on sprint. anything i should do after i flash Gapps? I'll try it again, though.Reflash gapps. Mms works for me just tested it right now. Are you using sprint?
I'm sorry, I'm afraid I don't know what you're asking me. Newbie here to everything, learning as I go, with the forums and root. Meaning...?Hmm. I can't seem to get it to work on sprint. Can you get me a log at when trying to send a mms or receiving one?
Well I am still on the 9/29 build and for the most part it works good. Nice to have 4.0.4 on my phone. The only main issue is the phone not ringing only vibrating, but I can deal with that. Text and other notifications seem to have sound. The other issue is I am now getting is the non stop ringing. Sounds like an old fashioned phone ring. This only happens to me when my paid Root Call Blocker app blocks a call. Regular calls don't ring just vibrate. Weird huh? I have tried everything to silence the ring and only a reboot will stop it. I just uninstalled Root Call Blocker. Comcast has a promotion running and they have been trying to call me, but I will just have to manually hang up on them. lol
I don't want to run the latest build due to other issues folks have been posting about. Same with AKOP. There does not seem to be much activity on here lately with CM9. If PhenomX could fix the 2 issues I addressed this Rom would be perfect for me. Thanks to him and everyone else for your work and postings.
