JHell
Shouldnt as updater script handles this
K thanks
sorry for the noob question, but this is just a rom made to look like kitkat, but not an actual rom based on 4.4 kitkat? the original just had 4.1, but the 'themed' part in the description makes me think its just 4.1 made to look like kitkat.
edit: after further reading it appears this one is based off of the one dragonhart6505 made: http://androidforums.com/awe-all-things-root/824562-rom-kernel-awesome-rom-v1-1-released.html
Love the ROM guys. Really brings b life to my phone and gets rid of all that VM garbage. Few questions. First off in the wizard it paused and wanted me to insert a sim card. The AWE does not use a sim. Was not a issue, I just skipped it and never seen anything about it again. Secondly am I able to use the rb3 kernel with this to allow over clocking or am I stuck with stock? If I can use a kernel what is the preferred performance settings for rb3 or is any reasonable settings safe too use? Finally I would like to know If the glitches with TrevE have been addressed. When I was on stock I used the most recent TrevE, however, when I was finished using it I had to reboot my phone to get it to stop broadcasting. This is not a deal breaker for me to keep using your ROM. Just a inconvenience.
Thanks for your time. Look forward to seeing how far this ROM will go.
Who can guess what this is![]()
Love the ROM guys. Really brings back life to my phone and gets rid of all that VM garbage. Few questions. First off in the wizard it paused and wanted me to insert a sim card. The AWE does not use a sim. Was not a issue, I just skipped it and never seen anything about it again. Secondly am I able to use the rb3 kernel with this to allow over clocking or am I stuck with stock? If I can use a kernel what is the preferred performance settings for rb3 or is any reasonable settings safe to use? Finally I would like to know If the glitches with TrevE have been addressed. When I was on stock I used the most recent TrevE, however, when I was finished using it I had to reboot my phone to get it to stop broadcasting. This is not a deal breaker for me to keep using your ROM. Just a inconvenience.
You'd have to use awesome ROMs kernel. Extract and flash awesome ROMs boot IMG. It works perfectly
This will break wifi unless you extract the drivers
Which I've been trying to do eehhhemmm......can't get it to work without breaking the zip, if I could I was gonna post it up for whoever wanted to use it.
By breaking zip do u mean not flashing with error?? U need to set permissions also
What's that kernels default clock speed.
It uses the rb3 kernel I believe which clocks out to 1.9 at max without boot loop or crash but usually I just set it to a max of 1.5 with smartassv2 and deadline.
Side note: I noticed something with the lock screen today. It has options to unlock to camera or Google now. However when I select those options it does nothing. I have to then go to the unlock to go to those. Shouldn't it immediately unlock to those without having to swipe a second time to unlock? Once again not a major issue just an inconvenience.
I have noticed the lockscreen issue only with gel, all other launchers i have used seem fine
I'm using gel and I haven't had this problem. The shortcuts work just fine for me. Strange.
No it's different, it only clocks to 1.8xx ....also he's asking about what the defaulted speed is, not the max.
