Root [ROM][4.1.2]AWE Inspired Moonshine White/Ginger V2.9a Final[Works with stock device]
I have having a problem as windows xp does not show the n800 ad being a device. I think that I must not have the correct drivers, I used pdanet. Also this is just a wish, will someone post some screen shots of the different apps. Thanks for any help you can offer.
U must select connect to pc software its stated in the stock device instructions:D
I'm totally loving the update! Great work! I just wanted to see if anyone else was getting completely random reboots. There seems to be no rhyme nor reason to when it happens. My phone will be just sitting there on a table, I'll hear it buzz, think I have a notification, and when I check it, it's rebooting. Any clues on how to fix? (I'm on the "black" version)
not sure on the random reboot, maybe try a reflash and post back:)
Just bought/ started messing with this phone, but I ran many different roms on my Triumph and had that same issue on occasion. Usually booting into cwm, doing a full data wipe, cache wipe, advanced > Dalvik wipe, and reflashing the rom would instantly fix it. You should be able to vcard your contacts and back up apps, prior to doing it.
i agree as the recovery's for this device is kinda buggy, i integrated formatting into updater-script to try and help:confused:, i had an issue with philz not formatting correctly so i switched back to cwm and have had fewer issues:D
Guys I am loving the black theme, looks great. I just have one problem (it's not the ROM because it's done it with all the ROM's, even stock) whenever somebody calls, it reboots. No idea why, would love any advice anyone could give on this issue because it is most annoying.
I would love it if someone could tell me if there is a way go to do it without a computer. I only have access to windows xp, not 7 or 8. And on xp it does not show the device.
What exactly are you trying to do? Are you rooted? Do you have a recovery yet? If that's the case then you can flash roms all day from your phone. If you don't have any of that, there's already been mention of an app called Root Master that roots without a computer. Its not on the play store and it's not in English, so being that I have not used it, I don't believe there's much risk, but read around (root with apk) you can flash a recovery with [root] recovery tools from the play store. Do a google search for the rooting app, if you need it. This forum isn't too large just yet, I'm sure you can find things referencing what I'm talking about.
[ROOT] Recovery Tools-Flasher:
https://play.google.com/store/apps/...s+apk&pcampaignid=APPU_ECFXU524HpCjyAStpIGgAQ
Once you're in a recovery (boot into with Volume down+power buttons or download titanium backup and boot into recovery with reboot options) you will then flash Roms by
First making a backup (optional, but recommended)
[Backup and restore] backup
....wait....
****Do a full clean wipe*****
[Wipe Data/factory reset] yes
[Wipe cache partition] yes
[Advanced] [wipe dalvik cache] yes
[Mounts and storage] format system, yes
format data, yes
format cache, yes
*******To Flash Rom*****
Let's hope it's downloaded
[install from sd card]
[choose zip from sd card]
.....go to the path where you have the Rom downloaded, click it..... then yes to install
......wait.....
Should say finished,
Go back to
[reboot system now]
Congrats!
Thanks, this is a huge help. I am rooted. So it is possible to install this ROM without a computer by following these directions? And do I have to install the cwm recovery to install the rom.?
I'm running the white version and I wanna move the clock back the right but I don't know how, can anyone help me please?
Moving the statusbar clock back to right requires editing an xml file in system ui, im looking into how to make it selectable in settings but for now it will stay centered
Any chance of using the stock mms.apk? Love the rom, I'm just not a fan of hangouts.
Its always a good idea to have a zip of the stock rom handy in case for whatever reason you want to flash back. Also you can then just rip whatever apk you would prefer to have from stock and replace it into your dd. It does need to be a deodexed apk. If you have to, use apktool to do it. Its self explanatory.
There really should be a fully stock deodexed/untouched zip in here...I'll probably get on that shortly
Thanks for clearing that up, I was thinking it would have to be deodexed first, wasn't sure though.
Ive actually been meaning to make a fully updated stock odexed rom :D
yes u have to flash cwm recovery to then flash the rom
OK, thanks. I was able to install the room.
It is great. Though the notification bar is a little weird, it is often grey when it shouldn't be.
I wanted to ask if anyone has been working on having the album artwork on the lock screen.
Sorry for not getting back earlier. I was trying to give it some time to observe results. I cleared cache/dalvik, reflashed, and my reboots are less often, but still occurring. I may try the white version and see if it likes my device better. Thanks again for all your hard work and advice.
