Root [ROM][4.1.2]AWE Inspired Moonshine White/Ginger V2.9a Final[Works with stock device]
On the first post it says you can install alternate launchers. However, for the Google Now Launcher it says:
Google Now Launcher "Flash in Recovery"
How exactly do you "flash in recovery"???
I'm a newb. Thanks in advance....
this really did help me out a lot with the random crashes from the stock.
the only problem i have is VPN when using a messaging application.
is there a recommeded one?
chompsms and cm10 messaging wont send/receive picture MMS.
not sure if this is what u asking I use go sums pro messageing
is go sms pro the simplest messaging app? i don't want any bells or whistles.
i just want something to send/receive sms and mms.
when i installed "Stock_White_Moonshine_V2.6" i did not have a sms app.
when i try to send mms with go sms pro it says there is no vpn specified on the device.
I. even using it for over a year send And receive pics and can get plug ins try it if u dont like install it go to play store him its weird I'm not using that from is our phone activated or are u using wifi
Hangouts is the sms/mms app need to enable in settings :)
Check out the OP!!! ROM updated... 4.2 QS panel the AweStruck kernel...updated framework, contacts, phone and lots more... Flash on flashoholics!!! :cool:
That's what I was afraid of. I'll stick to my current build then cuz I have no WiFi and it eats my data to reinstall everything.
Why dont you use TB? At any rate to get more accurate feedback/bug reports is why the ROM formats now. Too many issues can be related to a dirty flash.
Hey can someone please post a link to the google play services for the black theme? I kind of accidentally updated them.
EDIT: never mind. I'm going to switch to the white themed so that way I can keep it updated.
