edodson84
Android Expert
What rom were u on??The phone constantly rebooting, the battery draining really fast even if I don't use it, the screen freezing randomly, usually when i try to type something.
It was driving me crazy!
If ur getting reboots stock u probably have some type of hardware issue... If its within a year call virgin for a replacement... How do u like the rom??That's the worst part, it's stock!
I have a friend who rooted his Galaxy Ring an told me that it fixes some issues such as the screen freezing which is why I'm going to try this.
Flash it in recoveryI'm stupid. I got the OTA update message once or twice since updating to 2.9. I see the OTA fix.zip (downloaded it) but what do I do with it?
Any battery icon recommendations for the new addition coming soon!!??![]()
not so much anymore...Lulz...How about a pulsating glowing ripple looking one..... Or an extending lightsabre..... Or a spinning "one ring to rule them all"...... Or a UFO ejecting a beam..... Or a crazy parabolic vortex looking thingy..... Or moons orbiting a planet.... Or gandalf slamming his staff down!
i never had the need for wifi tether (been using usb tether) but i decided to try it recently and i couldnt get it to work. either i connect and have no internet access or i connect and the tether shuts down saying 'what the hell, your phone takes back control over wifi'
any ideas on how to fix?
i used the settings provided in op, also tried settings found in the another thread about it.R u sure u set it up correctly? I'll post instructions for it in a sec
thanks, im typing this connected to my awe's wifi tether!Try changing it to channel 11 and use all the settings that are outlined in the op. Mine was set to "1" initially, changing it to "11" fixed it immediately. Also, you can't turn WiFi on through the phones settings when you use it.
Chance for flashable stock theme? Gradients are not my friends.
)http://androidforums.com/showthread.php?p=6634869![]()
So, I'm guessing that this is that dreaded B06 update? I thought I read that someone was unable to root because they took it before rooting. Would this cause me to lose root if I take it? Any other known consequences to taking it? And, if I did take it, would the changes get removed if I flash a rom, or would it cause any problems in regard to flashing a rom? (just snagged the L you two put out)
