Root [ROM]A Froyo Rom 2.2.1
savoxis
Android Expert
A FroYo Rom​
Are you all ready for some Romen? I have been busy in the kitchen all day
cooking some up for you. I made this rom with simplicity in mind. It is just
a base for us to jump from. It is deodexed so this should pave the way for
themes on 2.2.1​
The Ingredients:
  • 2.2.1 OTA Based
  • Rooted
  • DeOdexed
  • Zipaligned
  • BASH shell
  • nano command line txt editor
  • Custom Font
  • Custom Boot Animation
  • Heapsize Increased to 32M
  • Bloatware Removed
  • Added Astro, Terminal and SpareParts
  • BUSYBOX!
To flash this ROM you must ALREADY be on 2.2.1 (FROYO)
with a custom recovery. YOU HAVE BEEN WARNED!
The standard warnings apply, flash this at your
own risk, I will not be held responsible for bricked devices or
even unsatisfactory behavior. You probably wont like this
rom until themes and addons come as is is stock with just
a few tweaks
Download
mirror​
Installation:
  • Download ROM
  • Place on SDCARD
  • Wipe Data/Cache/Dalvik-Cache
  • Flash
I have a full time job, an active social life, and more android projects on my plate than I know what to do with. That being said I dont plan on doing much updating or support for this rom. This will more than likely be the final release I do plan on releasing some flashable updates in the future. And if there are any bugs I will try to fix them the same way.
I did this mostly so the themers in the community would have a deodexed rom to work with. If you make a theme (either metamorph or update.zip) this should be able to apply to any other rom based off the same 2.2.1 framework (if its deodexed) I do plan on making a theme (porting one anyway remember that luna theme? Its open to port now) in the coming weeks.
I would like to thank Trident, for his updater script and some pointers on avoiding common pitfalls, and the guy that made the Scribble boot animation, its pretty cool, and whoever made the kitchen without it deodexing would be a PITA
Patches
01/27/11 Maintenance Patch:
Resolves error with permissions on /data causing soft reboots when downloading and installing apks from market, also reinstalls busybox and toolbox correctly. Flash in recovery, no wipe required. You only need this if you flashed the signed_012611_FroyoROM.zip package.
Download
01/28/11 Maintenance Patch:
Fixes USB/MS toggling to PC, added dependent system applications, lots of fixes. Flash in recovery it is necessary to wipe cache and dalvik-cache. This fix applies to 012711 FroyoRom build.
Download
Mirror
01/31/11 Maintenance Patch:
Fixes Gmail and adds YouTube. The main download has not been updated yet, this fix applies to all versions 012811 and before. Flash in recovery, no need to wipe
Download
01/31/11 Stock Email App UPDATED:
The Stock Email application, deodexed. Flash this in recovery, no wiping required.
UPDATED: Doesn't throw your phone for a loop anymore!
Download
Mirror
01/28/11 Stock Clock App:
The Stock Clock application, deodexed. Flash this in recovery, no wiping required.\
Download
Themes
01/31/11 Stock Theme:
This will flash the stock theme used in 012811 build. You can use this to go back to the stock theme from any of the other choices. Flash in recovery, don't wipe anything.
UPDATE: Update script doesn't tell you to wipe anymore.
UPDATE: Doesn't throw your phone for a loop anymore
Download
Mirror
01/30/11 JAMT:
Originally made by Classical Gas for Oxygen. Resupplied to us by GRZLA, flash in recovery dont wipe anything the font is included.
Updated: Death2All110 edited the background of the notification pull down to be semi-transparent.
Screen Shot
Download
01/30/11 Elegant Steel:
The Elegant Steel theme has been packaged for A Froyo Rom by GRZLA, flash in recovery no need to wipe anything.
Screen Shot
Download
01/27/11 Luna Theme (beta):
Remember the Luna Theme? Well the developer has opened it up for free porting! I whipped this together really quick and only did minor testing (which is why shes still in beta) As of now it is not the FULL luna theme as I was only able to easily modify about half of the apks. Flash this is recovery, dont wipe anything.
Screen Shot
Download
Mirror
01/27/11 GingerBread Theme:
I took GRZLA's Gingerbread4Froyo theme and repackaged it so it would work here. I didnt do a full port, you will notice the settings menu at the bottom has black txt on a black background. Other than that its all good. Oh and I changed the font aswell.
Screen Shot
Download
Mirror
Boot Animations
Flash these boot animations in recovery, no wiping required!
Nexus
Scribble
Screaming Droid
Retro
FAQ
Can I flash themes or apply metamorphs from 2.1?
No, themes for this rom will need to be made for the 2.2.1 framework, if you apply a 2.1 theme to this rom you will break it.
How often will you update?
Once the rom is good and I have confirmed it to be bug free the updates will slow, I anticipate doing a monthy update.
Why don't I see any scripts in the ROM?
Well. I have come to the conclusion that a rom should be about choice, with this in mind rather than focusing my energy on scripts to make changes to the rom, I will be making as many flashable "mods" and "themes" as I can. Passing the control down to the user.
Guides
Changing your Font
I have verified that the flashable font packs from XDA will work on this ROM with no modification, simply download your desired font, transfer it to your SDCARD and flash in recovery. These fonts found on XDA are not signed, so you will have to turn your signature verification in recovery off to flash them. There is a huge list available to choose from.
just installed it wiped everything and ive had like 5 random reboots seems to mostly happen when i try to install a app from the market
I have put a maintenance patch in the 2nd post which will fix the soft reboot issues. I also updated the OP with new files already containing the fix, you wont need to flash the patch unless you downloaded this this morning or yesterday
Great work on this ROM. But, for some reason I can not open Gmail. It just force closes instantly. Other than that, this ROM is great.
i flashed and now when i try to turn on usb mass storage it just unmounts my sd card from the phone and does not show up on the computer
Thanks for bringing this to my attention, didn't notice as I always use adb push. Working on it, little confusing but shouldn't be long.
So I was busy cooking tonight and was able to fix all the off flavours the ROMen! I have released another maintenance patch in the second post and I will update the main course with these changes tomorrow.
The new taste is accomplished by a moderate dash of missing dependent system files and some more salty permissions. I would have to say it is much better now.
I also just noticed when I went to set my alarm that clock 2.2.1 is missing. Im currently looking for a stock download but thought I would bring it to your attention. Thanks again for this great ROM.
I just saw your post and realized I didn't put it in the maintenance patch. Its called DeskClock and I was thinking it was a widget. Since I still had all my tools open I even made a nice little recovery flashable zip
Clock Flavored
Download Me Here
Flash in recovery don't need to wipe
A FroYo Rom​
themes on 2.2.1​
The Ingredients:
  • 2.2.1 OTA Based
  • Rooted
  • DeOdexed
  • Zipaligned
  • BASH shell
  • Custom Font
  • Bloatware Removed
  • BUSYBOX!
a few tweaks
Download
mirror​
Installation:
  • Download ROM
  • Place on SDCARD
  • Flash
ASWOME JOB!!! Works great so far keep up the great work.
Anyone care to post any more screen shots? Or does it just look exactly like stock?
^ EDIT.. NVM.. I see the OP got edited.
Has anyone tried both this and the Bryron ROM? Thoughts?
This may sound stupid, but is the main download updated, or do we need to flash that as well as the patches? BTW, savoix, thanks for the work on this and i hope that you get the thanks from others as well.
