Yes it does cause even with the stock ROM if you remove the SIM card the phone doesn't work. No calls,No Text, and No Data.
weird didnt someone say the made calls and sent text??
I can confirm that the Connect gets no form of mobile service (phone calls, text, data... etc) without the SIM card on the stock rom.
However I didn't test to see if I can still make calls/texts on cm10 without the SIM card. Perhaps someone can try it and see what happens?
Do you mean you can't make any calls with SIM in? At first mine could only receive calls, after running for a while and playing around with phone settings I could make/receive calls and SMS was working fine. When the ROM initially boots up, there is NO svc at all. It will show up after sitting for a while!!
No, I meant currently I'm using stock VV3 and if I pull the SIM card out I get absolutely no service (despite the fact that the SIM card is supposed to be only for 4G)
Now I haven't tested if the phone still gets service or not without the SIM card using cm10, I think we are trying to determine whether cm10 is reading the SIM card or not.
Now that I'm home I'll download 0309 and try it out.
Has anyone tried updating the prl?
Actually i did it connected to metro and said it updated correctly but no potatoes...
Are you still running JB? What PRL does it say under phone info?
It said 3032 before and after...
OK I tried 0309 with no SIM card and it said "No SIM" at the lock screen so I guess that kinda debunks the theory of CM10 not seeing our SIM cards.
0309 shows MetroPCS on lock screen but shows 'unknown' under ICCID in phone status. Is this why data is not working?
was you overclocked to 1.5 b4?? Try using a lower oc clock setting.the ROM is great, only problem is of course the mobile data and the camera. It also feels clunky and terms of performance, but I'm sure that can be fixed. My LG Lucid battery is also running at 82 degrees rather than 50 degrees, but I'm not sure if that's the ROM or not. Other than those things, I'm really loving the ROM. Thanks for all of the hard work![]()
Seeing and reading is 2 different thing.OK I tried 0309 with no SIM card and it said "No SIM" at the lock screen so I guess that kinda debunks the theory of CM10 not seeing our SIM cards.
Yeah, I set it back to 1.2 ghz, still hot. :\
Even without any network data this ROM rocks!
Soo I'm on a clean install of cm10 and all of a sudden 1x data pops up. In fact I'm posting on it to test.. I set it to edvo/gsm auto and it worked. Anyone else had that happen?
