Root [ROM][ALPHA] Quattrimus ICS (CM9, AOKP40)
Lykarsis, you could put the power control widget on your desktop. It functions the same way.
That doesn't have a data toggle either. And honestly, its not that big of a deal. I have extended controls so that works fine. Its just one of those "I want to have all of my toggles in the same place" things.
If someone can find a simple fix, let me know. Otherwise, I'm not to worried about it.
I wanted to share a little trick for everyone who gets annoyed having to wait 5 minutes at the activation screen. If you want ot avoid this just don't install gapps when you first flash the rom. Boot the phone up after flashing the rom and get everything you want setup and then go back to recovery and flash gapps later and you will never see the activation screen :]
I stumbled on this on cm9 because I always forget to install gapps, then I forgot to install it again on aokp and both times I didn't have to activate, so I put two and two together.
everything seems to be running good. Seems to be a bit smoother than cm9 but I don't know. I love the extra status bar features, and I'm very glad to have my torch in the notification window again, I use my phones led light almost everyday so it's nice to have it there.
Great Work tdm, neph, death, and play, you guys have made having a spectrum a lot more interesting than it otherwise would have been. if only mt would come back :/
Only thing about cm9, and now aokp, is what the heck is up with the lame mascots lol. First that annoying little blue demon on cm9 and now a pink unicorn!?! seriously! I mean come on, you make a nice rom and then decide it's mascot is going to be a pink unicorn. Although the pink unicorn boot animation is less annoying than the blue demon one of cm9
Gotta agree on that. The CM10 boot animation is my favorite one I think.
Yeah cm9 boot anim is pretty horrible because of Andy. If they had a better logo critter, it wouldn't be bad at all.
Fortunately it's easy to change. Use the cm10 anim, it's much better. :)
Yea, I know I can change them but I'm usually too lazy to. Anyone have a good website I can get some boot animations from?
I am on aokp. The toggle isn't there to select. That's my problem, not that I can't find it.
Edit: I also re-flashed the ROM and its still not there. Is there anyone else who has the data toggle?
These are my options.
Not there for me either.
I had data when I first loaded aokp40(coming from icy fusion R1.3). But it vanished after a little while.. and i got an error message when i rebooted, saying the phone process stopped working. Couldn't get it back by toggling the radio on/off in the hidden menu. Tried dirty flashing it again and got no results. Wiped everything and installed rom again and now only have 3g. The preferred network type defaults to cdma auto. Gonna restore back to icy fusion and see what happens. Great job on getting all this up and running!
  • Like
Reactions: tdm
Yeah I had to add some stuff from cm9 to get lte support in aokp40. I'm sure I missed some things.
Hopefully I can get phone and data working on jb soon so I can retire the aokp40 code.
Looking forward to CM10 and aokp41. but thanks again for going back and finishing this one up. gives everyone a lil something different to play with till you get data going on jb
Ok so AOKP has this power save option in settings. It warns that it could be sent in an infinite loop of errors if it is activated and is very buggy. I'm curious if it will actually work with out the errors but I'm afraid to try it. Has anyone already used it/ is still using it without errors??
I've done a good job of confusing myself here, so I just want to ask - is MMS sending working on the beta1 CM9/AOKP40 roms?
MMS send is not working yet.
Any way to skip activation on aokp as I don't have service on my spec anymore
Do not install GAPPS after installing the ROM and let the ROM boot once and set it up. Then reboot to recovery and install GAPPS....no activation required. :)
