tdm
Android Expert
Any way to skip activation on aokp as I don't have service on my spec anymore
If you don't have service, grab the jb build on xda in the nitro section. Ril is the only thing that isn't working on the spectrum.
MMS send is not working yet.
can anyone else verify this is true? Was about to flash this?
also when you say bluetooth kinda works....you think it should still work for BT input (non audio) devices?
Lol. I actually love the unicorn and would have aokp ony transformer still if the rom was still supported.Only thing about cm9, and now aokp, is what the heck is up with the lame mascots lol. First that annoying little blue demon on cm9 and now a pink unicorn!?! seriously! I mean come on, you make a nice rom and then decide it's mascot is going to be a pink unicorn. Although the pink unicorn boot animation is less annoying than the blue demon one of cm9
MMS is not sending. says address is not valid.
preferred network was set to "unknown" says its on LTE. i started to play with the network settings in *#*#4636#*#* and now i am stuck in eHRPD or EvDo or 1x
**edit**
i am also roaming.
Tdm, have you merged your changes into github? I would like to merge some of your changes into the kernel I'm working on.
It still defaulted back to CDMA prl when I flashed back to icy fusion. Had to put it back to the lte/CDMA/evdo to bring back the 4g. Gonna flash aokp again and see if I can find something specific that triggers it
Does 4g work on aokp? Cus I haven't been getting 4g since I flashed it
For those that haven't seen, I got the radio and 4G on CM10 so this ROM will have a very short life.![]()
do you know if the data toggle is in aokp 41?And I for one am very happy about thatdo you know if the data toggle is in aokp 41?
Which model do you have? I'm thinking about buying one for my wife, to replace her aging laptop.
