Pissed, flashed and I can't text. Anyone else having this issue?
Nope, I have been texting just fine. Do a clean wipe and reflash might work.
Texting works for me too.Nope, I have been texting just fine. Do a clean wipe and reflash might work.
This is a bug with ICS keyboard source, I noticed it when the first batch of ICS keyboards were ported to older android versions and people had to fix them manually. I'm guessing Google hasn't fixed it or CM9 hasn't updated from Google's source.
Yeah, CM9 in itself is still a work in progress. Which is pretty obvious when you go settings and see all the place holders. One thing that bugs me is the percentage battery indicator is not enabled yet, I guess we'll just have to wait.
Anyone tried the Google Chrome for Android yet? I downloaded it but it keeps freezing up on me. Can't move through tabs or search.![]()
I got the same and when you go to a site there is nothing a waste of a app
Same thing with the battery usage monitor, unfortunately. The app by app usage data, I mean. The line graph works, though![]()
Anyone else having wallpaper scrolling issues with Trebuchet? I don't want to go through the effort of using another launcher when Trebuchet is fine. I'd like my wallpaper to scroll, but it won't for whatever reason.
you make this phone worthwhile!The line graph works, which is amazing but I can't seem to set a limit for the data. As you probably know VM will soon be enabling a data cap of 2.5GB, I'd just like to see visually how close I am to meeting that point. Most of us here on the forums are probably pretty heavy internet users, and as soon wi-fi hotspot comes back there is greater possibility of getting throttled. I tried to use this guide: Tips and tricks for your new Galaxy Nexus | ExtremeTech, but that's probably just another thing that CM9 needs to be updated from the google source.
http://www.extremetech.com/computing/109277-tips-and-tricks-for-your-new-galaxy-nexus
lol. I thought I just wasn't doing it right. Or maybe it has to go for a few days first or something?
Just thought I'd share, for those that weren't aware.Pissed, flashed and I can't text. Anyone else having this issue?
Yep, no need to wipe all data. Also make sure you flash gapps after flashing the update each time.
No need to flash gapps again if you are installing another version of CM9 as long as you are coming from CM9. I must have installed several CM9 versions in the past few days with no issues whatsoever. In an unrelated note, on HP TouchPad, I don't have to flash gapps after every CM9 related install.
Btw, I think there is lot of confusion on what or when to do these wipes. Let me clarify:
1. If you are coming from the same CM base (CM9, in this case), then all you have to do is Wipe Cache Partition and Wipe Dalvik Cache and install the ROM.
2. If you are moving from CM7 to CM9, then do a Factory/Data Reset and format /system partition to have a clean install. Factory/Data Reset wipes /data and /cache partitions and clears Dalvik Cache too. So, no need to do Factory/Data Reset AND Wipe Cache AND Wipe Dalvik Cache.
We've documented issues with gapps after flashing a CM9 update. Flashing gapps each time prevents these issues.
