death2twitter
btwlancoex is still in the latest build. Cleared system before installing and everything, I opened up the zip and checked as well.
I had that happen as well, but I'm pretty sure it's due to an incompatible/buggy widget, or a widget that CM9 doesn't agree with somehow. Once I removed some apps that I knew had widgets and that I didn't really need, that crash stopped. I would try removing apps with widgets one-by-one until you find the culprit.So one bug I noticed that is fairly consistent is when swiping through widgets. About the 5th screen of stock widgets, trebuchet (or however its spelled) crashes. I've found if I want a certain widget, I have to download one that starts with the letter A-F, or I can't swipe deep enough into widgets. My suspicion is that one widget is causing the crash, but not confirmed. This has to do with the launcher, right? Are we tied to this launcher due to CM9?
why isn't youtbe working right on ics 9.0.0 rom and when i download adobe flash i cant even go to the site and flash isn't even reading like whats up with that
i now that but it stop then start then start ok why isnt flash working it downloading and every thing but its not doing not you cant even go to the site or test itYouTube works fine as long as you play videos in hq
Quick question, is it okay for me to download these build's straight to my device over Wi-Fi. I'm sure it's safer to download them on to my computer and then transfer them later, but I'm pretty lazy.
I just flashed 0.6.3 and my home button doesn't work again. Wasn't it fixed?
I have some problems though, im on a fb400/fb0 U9000 x6 Huawei device.
While using the text messaging app, I was switching between uppercase and lowercase (you know standard typing and whatnot), but at one point all the keys on the keyboard were uppercase except for the keys that I had recently tapped, which were lowercase. everything typed out just how I needed it too, but visually it was odd. I'm not sure if this is exclusive to just the text messaging app or if it was system wide. It only happened to me once.
and it seems like, the buttons Back and menu is flipped/replaced?
Yep, no need to wipe all data. Also make sure you flash gapps after flashing the update each time.Just flashed and I'm making this my everyday rom, even purchased Titanium Backup Pro just for this. Just one quick question, upon release of other versions(which seems to be every night), would I just Wipe Cache? I don't want to have to wipe everything and restore it for every update.
Anyone having 3g not working after the phone sits a while? Only way to get it to come back on is to reset connect via air plane mode.
same problem on the 0.6.2 rom with the data connection dying. Either reboot or the Airplane mode fixes the problem. Just flashed to v0.6.3 this morning but the phone has not sit idle enough to have the data problem yet.
so far 0.6.3 works great but the data cut off is still in the new rom too.
hope that can be fixed soon.
thanks
BD
A few pages back, someone suggested "connection checker" from the market. I've installed that and it has been pure bliss for 3G. Try it...
