NaterTots
This is not mine. Just wanted to share a new ICS option.
XDA Thread
[ROM] Android Open Kang Project - Supersonic Build 22 - xda-developers
"Android Open Kang Project
Big thanks to Evervolv for their device tree and vendor tree!
features
there are many many more tweaks/adjustment throughout the whole ROM, take a look at the change logs ​
built from AOSP -- using 4.0.3
power menu (source)
ICS style toggles
superuser & busybox built from source, included
deodexed & unsecure boot.img (for adb remount)
Facebook contact sync
ROM Control application lets you take control of your ROM. Customize it how you want it.
Navigation Bar options & layouts (search bar layout, menu visibility options,etc) -- long press search button enabled
IME Switcher toggle (show/hide notification when you type)
Customize your carrier label
Override lockscreen timeout (ie, use Android's timeout when turning the phone off, so it won't lock itself)
LED pulse timing options
Statusbar toggle options
much much more in there
battery mods built in (including circle mod)
Unique Power Saver functionality
Turn data off while your screen is off (GSM phones can switch to 2G)
manually sync at a time interval for all your accounts (Gmail, etc)
Check out all the options in ROM Control
change log available here
flashing instructions
1. Make sure you're on the latest CWM
2. MAKE A NANDROID
3. wipe data/factory reset in recovery -- a must if coming from a stock-based ROM
4. flash ROM
5. flash Gapps
6. reboot
download
https://sites.google...angproject/home
Find builds and milestones here
Join us on IRC for AOKP chat/support. #TeamKang @ freenode
obligatory
We spend countless of hours doing this for next to nothing. Posts, views, and donations encourage me, and everyone else who helps out.
Donate to ProTekk
Donate to Roman
Donate to Whitehawkx
Donate to Jonathan Grigg
Donate to Zaphod-Beeble
Donate to CyanogenMod
Every donation is cherished and loved.
source
Check out the ROM source on github. Open source, in the spirit of community kangage.
If you'd like to help with AOKP, please don't hesitate to contact me. I'd love to get as many developers in on this as possible!"
Edit: There are some Screenshots on page 3 of the thread.
XDA Thread
features
power menu (source)
ICS style toggles
2. MAKE A NANDROID
4. flash ROM
5. flash Gapps
6. reboot
download
obligatory
Donate to ProTekk
Donate to Roman
source
