Root [ROM]Angablade's Mixed Build
Zephyr101
So like some of you may have noticed Angablade posted a link to his 3 part build of CM10 on BobZ's CM10 thread, and all I really decided to do was just kind of help him out just a bit by combining all 3 parts into one zip so that other users in the motion community who don't exactly know how to join 3 part files don't have to go through the hassle of figuring out just exactly how to do it.
So I created this thread not only to simplify the process of flashing it for the average user but also so that testers can give Angablade feedback without it getting lost sometime in the future around BobZ's thread.
Anyways without any further ado, here is Angablade's Mixed ROM
https://docs.google.com/file/d/0B13pfTXQtBOicGJTRzNrRFJaZW8/edit?usp=sharing
I appreciate the hardwork and I would like to install this but I need these 3 things:
1. How to install
2. What works and doesn't work
3. Screenshots
If possible...
Thanks
1. How to install
3. Screenshots
If possible...
Thanks
1:install like any other cm10 rom refer to one of the other cm10 rom's directions
2:edit: nothing works because it doesn't boot
3:i would assume it looks just like any other cm10 rom
Wow its like that...
Just asking for some help for some of us that are starting to install ROMs without going around and searching for answers...stay classy
How do I install this?
Download the .zip & copy to phone or sdcard (make sure 4g or wifi is enabled if dl'd from phone).
Zip can be installed from either internal or external sd in CWM (Which ever you copied it too!)
MAKE A BACKUP!!!
DO A FACTORY RESET!!! - this will wipe data & cache!
Go to install zip from sdcard
Choose zip from sdcard
Select cm-10-xxxxxxxxxx-UNOFFICIAL-l1m.zip
Confirm
Repeat Steps 5 -8 for gapps
Reboot
Uhmm..this ROM didn't flash at all...it just gets stuck at the lg logo screen.
I think the update script which I borrowed might be the problem... but I know it works, I am on it..
@Angablade, any chance you can explain what you did so it can be implemented into the source builds???
yea i tried messing with the script and even tried removing all the setperms etc.
and firmware but still stops at lg logo.
did you just copy the system folder?
It's HK's rom, with PG's Pasted over. It filled in the holes for some system files. Using HK's HW folder, then installed Liquid Smooth over top. Installed Liquid smooth over top. Installed the 4.3 Google Camera from the HTC one. Added some init.D scripts, and messed with the build.prop file. tweaks to the sound driver, turning the volume way up, but turning the equalizer down on higher end for alloted sound step mod to actually have more control.
OK, so I tried a lot of different ways to get this to work, but all have failed. So how do I get this to work exactly?
