Root [ROM] Angry Bean / CM 10.1 [build 08.08.13]
love this rom, best one i've used on this phone so far
is there any way to integrate the wimax log fix into the rom, or will i just have to keep flashing it every time?
also, is there an alternative program to use to be notified of updates since this isn't located on goo manager?
I will be working on adding the WiMax log fix hopefully next release. As for updates you will be forced to check on the AF forums :p Since goo always has ups and downs from time to time I have always preferred to host the files myself on my web hosting server.
4/4/2013
∙ WiMax log fix - Ramjet73!
∙ Weather is working on lock screen - CM
I was going to wait for a few days to release but I decided to pull the trigger. I have added Ramjet73's WiMax Log killer to the ROM. The other great feature is the Weather Lock Screen is now working which is a nice bonus so I had to pull the trigger. I will be holding off for a few days for the next release to allow Chairshot and myself some time to add in some more fixes.
Enjoy :D
I found out that if you change the debug.composition.type in the
build.prop from dyn to gpu it fixes the YouTube problem and allows games like shadowgun: deadzone and dead trigger to be playable because it is basically making the phone's gpu render the graphics instead of the cpu. This allows for better graphical rendering of everything.
So it would look something like this:
"debug.composition.type = gpu"
disabling HW overlay in the developers option would do the same thing, but you would have to do this every time you reboot the phone and that gets annoying.
so could you please implement this fix in your rom pretty please!
Just got my EVO and of course I flashed a G60 ROM because of all you've done for my triumph! The ROM is smooth. I've only had a few minor problems.
Google Now force closes whenever I try to use it
The controls for a Snapchat dissappear, I can still press where the controls would be and it works but I can't see them, same happens when I watch a video from the browser. I can't see the pause icon, slider, etc. but if I press where they normally would be I can still control them.
I should mention that I didn't flash the joeblowhacks or whatever but that's because I followed the " S-OFF, root, & Fix Everything All-in-One!" guide and both joeblowhacks and the All in one guide said they would bring me completely up to date so I figured it didn't matter, but could this be why I'm encountering these issues?
Thanks for your work g60!
Is there ever going to be working 3d ? i saw a app that will activate my 3d screen on this rom. I know its a silly question but after seeing this app I thought it might be possible.
Ah that fixed it. Thank you! Any insight on the whole joeblowhacks thing? Do I need to do that or am I fine?
You should be fine, if you see issues apply the fixes.
Got a link for the App?
Yes, each one is for a different unlock option. So if you do screen, or password, or pin, or slide each one allows for different options.
I can't get 3G to connect.
I have:
S-Off
Hboot 1.50.5050
Radio 1.09.00.0706
PRL 61009
Under Settings -> Wireless & Networks -> More -> Mobile Networks
I have Data enabled, Data roaming, National data roaming and Automatic checked.
* I tried unchecking Data roaming and National data roaming but that didn't help.
Is there something I am missing?
I have:
S-Off
Hboot 1.50.5050
Radio 1.09.00.0706
PRL 61009
Did you did a dirty flash? Normally I just do a full wipe so I do not have those issues.
