Wow, so many updates since my Evo V died. Getting a new screen soon though. Then gonna replace it. Learned a lesson: Slamming in the car door kills the phone. SO. Don't do that
Looking great though, g60 and Chairshot. Once I fix the screen, I'll be flashing this and Dirty Unicorns. (I miss flashing ROM's)
Edit:
Should have checked the mail earlier...here it is! Now to replace the screen.
Probably. I like having a backup phone.![]()
Is there ever going to be working 3d ? i saw a app that will activate my 3d screen on this rom. I know its a silly question but after seeing this app I thought it might be possible.
So did I miss a post where the voicemail notifications and visual voicemail app problems were solved? Because I just discovered that both are working perfectly for me on the latest build of this ROM.
Excellent ROM by the way, all of your hard work is greatly appreciated G60.
Wifi tethering works perfectly for me with the stock tethering app.
There's a stock tethering app? Please enlighten me.
Yes, I meant the tethering functionality built into the ROM, as opposed to the extra, third party tethering app required on Harmonia and other non CM 10 ROMs I'd tried. I've added mine to the standard notification area power widget.
Umm really? What did you do? Please share![]()
//ANDROID:Joe has sent you a Sprint Voice Message. Call 408-970-0000 to listen. MMSN, <random sequence of characters>//CM
made this my daily, smoothest jelly bean 4.2.2 out there. Only problem is camera with apps, for example when using snapchat the controls on the screen dissapear but you can still use them. Its weird, but great rom otherwise
Can't receive any text since I updated to the newest one. Having couple issues with this update, some apps won't download also.
This happens to me also, as well as in youtube and other video players. This really is the only issue that I am having, otherwise it is a great ROM.
