Has anyone gotten group messaging to work?
It sucks to try to tell my iPhone friends about this great ROM but then have to ask them to send me the group text individually because I can't read it.
Is it possible to get Slide2Wake functionality with this ROM? MidnightROM did this and it's one thing I used all the time since my power button is a bit flaky.
How do you enable it in this ROM?Sweep to wake works on here. I use it all the time.
I'm not getting voicemail notifications period. I will try to install the VVM.apk but is there any way to just get a normal notification for voicemail?
I have to first touch the screen to activate the slide unlock. Then I have to slide to the right to unlock. Is it possible to get the old unlock screen back?Using the new "slide" lock screen for JB is very similar to the old slide unlock. One ring in the middle that can be used to open applications, or to quickly unlock.
Maybe there's an easier way to do it with this ROM. This is how I'm doing it:I may not be understanding what you mean correctly but why is touching the screen to activate the slide required using the JB one? I just slide to the right from the start, figured you were just asking for cosmetic reasons. I know the Evervolv ROM on XDA has the unlock screen option you posted earlier if its a big of deal but not going to suggest trying that ROM in another's thread.
1) Press power button to turn screen on.
2) Touch lock at bottom of screen.
3) Slide lock to right to unlock.
Ahh, that did it. I already had swipe2wake enabled and changing that setting eliminated touching the lock. Thanks.You can use kernel tuner to enable Sweep to Wake, that would eliminate the pressing of the power button. Other than that it doesn't get much easier.
Edit: I think the problem you may be running into is the "maximize widgets" setting;
go to System settings>lock screen> from there uncheck the "maximize widgets"
That way the lock ring will be centered, full size and all you'll have to do is slide it to unlock, instead of touching first, THEN sliding.
I get twelve hours with heavy to moderate usage, twenty to twenty four hours with light usage. I used to run midnight ROM and thought that was the best possible ROM for battery life, but with the same settings I achieve very similar results on Angry Bean.
