fivestardunk
The app Textra has group messaging MMS that works
So I wiped System and reflashed gapps and now my phone is stuck on the white HTC screen booting. I had to restore a nandroid of MidnightROM to get it to boot.
Will wiping system remove any apps or other data? Is there a way to backup the current stuff and then restore later?
Does anyone have an issue with the 3G data connection sometimes dropping off?
For example, I was in the car today, and I pulled my phone out to look something up. I opened Chrome up, but it said I had no internet connection. The 3G indicator said I had 4 bars, but the indicator was grey. I fixed it by toggling 3G off/on, but is there a more permanent fix?
Anyone having issues with this build randomly changing my ringer either completely off instead of vibrate? I will set it to vibrate, then check my phone later noticing a has missed calls and texts because its now on silent. Not sure if I am hitting something or whats going happening.
Yeah, this happens to me most often when I have been connected to wifi for awhile. Like you did, I always have to toggle the 3g to get an actual connection back.
In general I have actually been a little disappointed with my signal strength and stability over the last couple of builds. With the latest change in RILs, I've actually noticed my signal is quite a bit less stable. I was hoping it would sort itself out and stabalize after a running the rom for a bit, but unfortunately it has not :/
Will make this quick as its late.
Added a bunch of Audio changes. Most came from the 20 or so hours of trying to get HDMI working. Still not working but less log errors and at least now is recognized by my TV when plugged in, still no picture though. Added some files in the
No
So far, so good. It's running very stable. I'm curious about this HOTPLUG governor. What is the benefit of it over any of the others. I honestly don't know the difference from one to the next and have been going by the names. POWERSAVE is a little less ambiguous a title than HOTPLUG.
It keeps on bouncing out of hotplug mode.
It doesn't seem to want to stick to any governor other than ONDEMAND.
I set my first core to HOTPLUG but when I went to set my second it shut off the servings core and defaulted back to ONDEMAND.
What app are you using to set the different cores? I've used Kernel Tuner & Trickster Mod and both of them give me all sorts of problems like SOD's and random reboots.
Oh, and yeah, Hotplug isn't sticking for me either.
I have tried both Kernel Tuner and the ROM's built in performance screen under settings. Both force ONDEMAND.
Yeah that
Success! What do you recommend for governors for maximum battery yet optimum performance? Should both cores be set to HOTPLUG or just CPU0 and set CPU1 to something different?
Still having it forced back to ondemand even after reflash from the zip on the website.
there was a little mention of it earlier, but anyone know why the AOSP helper from Juice defender isn't compatible with this ROM? OR if that's fixable on the user side?
