justbenny2k
I got errors trying to install the vm zip versus the Angry Bean vm app (which I, of course, deleted already). Otherwise the 6/7 build is working fine. I, too, am still having issues with hotplug.
Hotplug is working wonders for me. I am going on 20hrs and 20m of use with 28% left over clocked to 1566.
Ok so I must be the unluckiest. I decided to switch to HOTPLUG and it locked up my phone and went into bootloops again. I had to restore my backup :-(
Downloading now and I'll apply hotplug immediately after setup and report results
Edit: not having any of the issues I was before with hotplug, in fact it's running sexy fast as hell. So far so good thanks alot for the work.
Ps followed instructions of setting governor in cm performance settings right after setup. Using default row scheduler still too
What happened when you started reinstalling your apps? Did you find one of more that was causing conflicts with hotplug?
I have actually reinstalled all of my regular use apps and zero issues so far, performance is still fine. No hang ups or reboots, I honestly think it had something to do with kernel tuner last time things went haywire
All apps were reinstalled either from market or from the apk. Did not restore any data just re signed into everything
Only issue I had had nothing to do with the rom, I flashed a new radio and has to put my sd card in Pc to remove pg86img so I could boot to recovery again to format cache to get phone to boot again :-D
In the absence of Kernel Tuner, have you gone into Performance and checked the governor? I just did a clean install and skipped the Google stuff. HOTPLUG set and was running smooth until I rebooted. My phone kept defaulting to ONDEMAND.
Did you check set on boot? I have had no problems with settings sticking
I didn't even think to check that. It's set now. So the conflict is with Kernel Tuner? How do I set the second core to HOTPLUG? How do I enable sweep2wake?
I believe CM performance handles that, TBH its ran just great and battery life is alot better than anything before with cm4.2.2, so set it in CM performance and forget about it. Been running this with Everything.me launcher and playing music and youtube vids off and on all day along with texting and tapatalk and im still at 50% battery. Good work Chairshot and g60 of course
As for s2w i dont use it, i dont know if its in the kernel, and youll have to figure something out guess![]()
Since flashing a fresh ROM so I could get HOTPLUG to work I had 2 random reboots. The second one froze in the middle of the reboot on the CM logo animation. Oh well... I installed my backup running ONDEMAND until I can figure out more.
I did a clean install yesterday, changed performance settings to HOTPLUG before signing in to Google or installing any apps. Set everything up and phone was great for the day until later last night, went to Kernel Tuner and saw the second core was set to ONDEMAND and kept turning on and off. Managed to get it to HOTPLUG the split second before it disappeared. Put the phone in my pocket and went out - the next time I pulled out my phone, it was stuck in a bootloop. Tried to reboot, still bootlooped. Reverted to previous build.
Has anyone else had issues with battery drain even though they barely use the device? what is everyone else averaging in terms of battery life?
In my old ROM when I received a text the unlock screen showed the text and I could drag the text to the bottom and then that text would be brought up once unlocked. Is there a way to do that with this ROM?
