Hmm, the MidnightROM I was using had sense removed. Is there any way to get that functionality on Angry Bean?No that's only for sense (spelling might be off) based roms.
6 days ago, I upgraded to 6/4, but haven't upgraded since then. Due to SMS problems, reverted to 5/17 back up. Is it possible to safely upgrade to the latest version without full wipe? What are the benefits/detriments of such an upgrade?
What recovery are you using? I have had no such problems. I am on the latest build. What is your procedure for flashing?
I'm using TWRP 2.5 and with the exception of hotplug not working this ROM works great for me. Are other people using 4EXT? Could that be the culprit?
I am using clockwork mod 5.8.0.2 touch and I tried to use the MMS zip fix and this error. The log is attached. https://docs.google.com/file/d/0B6_Tz9dzbmKxekFmZC14RzZZSjg/edit?usp=docslist_api
Guys. IMHO the only recovery that you should use is 4EXT. You wont get that problem using 4EXT
get out of the stone ages...lol try 4EXT you wont go back... trust me
For you guys successfully running HOTPLUG, are you avoiding Kernel Tuner completely? Is there another way I can enable sweep2wake without it?
There's a couple small app on Google Play that can enable/disable sweep2wake.
