Root [ROM] Angry Bean / CM 10.1 [build 08.08.13]
I have heard a lot of people recommending Battery Monitor Widget for extended batteries. Some say that it is a must for them. I don't have one though, so I wouldn't know.
I would like to let you know that I have just hopped on board with your ROM and it works WAYY better then what I was using earlier. I am pleased and can't wait for more updates and what you have to offer. I would like to know one thing, will there be any changes to the way 4G status icon is displayed? I would like a 4G icon if possible to display when I am connected to WiMAX if that is not a problem to ask?
I just noticed I'm having mms receiving problems on the 6/7 build. I sent a mms and received 4 that were sent to me over the weekend. Would flashing the old mms fix be an issue with this build? I never had an issue when I had to manually flash it.
Open the Voice Dialer app and say, "Open APNs". Select Sprint on the screen that pops up. Then go into your text app (I use Chomp vs stock) and make sure "http://mmsc.vmobl.com:8088/mms?" is entered on the MMSC line. Leave the rest blank.
I already checked that and it was correct. I'm just wondering if something was reverted in the mms.apk. The only time I had this issue before was when the vvm text notifications weren't blocked, which is occurring again with the newest build.
Is there a way to change the kernel to allow a different mah? Its only charging the battery to 1700 ~ 2500. (supposed to be 4000mah) Its it saying that an 1700mah battery is inserted. I've heard that the battery has a high point of 4147 mv.
In Battery Monitor Widget, there is a way to change the mah of the battery. Not sure what it does, but I think it changes something in the system to show you have an extended battery, but again I am not sure. In the app, go to Calibration and hit Create to add your extended battery. It should work, but if not then I am not sure what else you could do.
Tried that already the kernel is still reporting a 1700mah battery.
Which voice mail app are you using? The chairshot one kept failing everyone I tried to install it but the angrybean one worked just fine. Have you tried that one?
I see. Hmm, where do you see the kernel reporting the battery this way? Is it displayed in the settings or something?
I was using an app. When I told it to take the mah from the kernel it got a string of 1700. Doing some research of the kernel is not programmed to take extended batteries correctly it will cause problems with charging and showing correct percentage.
How did you get it to do this? I'm planning to get an extended battery and want to see if mine reports this as well.
I don't have the angrybean one anymore. is it the same one that's posted in the vvm fix thread? I'll flash that one and see if it does the trick.
Is anyone having MMS issues on the latest release? I am still on an earlier build and was considering an update? The build from 5/17 is my current daily and experience no issues. I was just curious! Thanks
Yeah I have been receiving quite a few MMS with no problem, but over the past few days I have gotten word of at least 3 that I never received, (and one of those supposedly included text for an invitation out to lunch, argh). And that doesn't include all the ones I don't know about!
That must of sucked.
Still getting a glitch with the battery usage. I'll have 60 percent and if I reboot it will then say I'm at 30 percent. Stock battery BTW. Edit..... I then reboot once more and I'm down to 17 percent. Reboot once more but this time into recovery and 4ext says 17 percent as well
