sugarshine
hi i just flashed this rom yesterday & now i have no data
what could causing this?? maybe i have the wrong radio. what radio works best with this rom? any help would greatly be appreciated & thanks
hi i just flashed this rom yesterday & now i have no datawhat could causing this?? maybe i have the wrong radio. what radio works best with this rom? any help would greatly be appreciated & thanks
I found a method for improving wimax, it involves entering the msl code (which I was able to obtain) but I can't enter it, normally you're supposed to dial ##3282#and it's supposed to ask you to enter the msl code to get to a menu to alter wimax settings. But when you dial the number in our rom it just attempts to make a call. Is there any way we can access this menu so we can fix wimax?
k thanks running the rom now but how can i change the weather degrees to Fahrenheit.it's in Celsius nowalso where can i get the vm voice mail app?
Ok, to change the weather widget to Fahrenheit go into Settings -> System -> Clock Widget -> Weather Panel -> uncheck Use metric.
For the voicemail. Boot into Recovery and flash it. Reboot into the ROM and open the app so it can provision. You'll get an error but don't worry. Reboot your phone again into Recovery and flash the app one more time. Reboot once more into the ROM. Open the app and let it provision. You'll notice this time the app's theme is now dark. That's it! You are good to go
http://chairshot.vmobi.us/shooter/CM10.1-MMS-VMM.zip
I tried four different radio versions and I never noticed any difference.
Chairshot, have you looked at the code for the Halo notifications now that PA has open sourced it? Is it compatible with AngryBean?
Hey, I've been using this ROM for the past month or so and it's been running great.
Anyways, I'm actually just starting to learn to develop Android ROMs (I'm a good programmer in general, but have virtually no knowledge of Android development) and was going to start to learn by messing around with the source of this ROM. However, before I start making builds and flashing them on my phone, I was wondering what is the best way to modify it so it will always start in airplane mode?
As I'll probably be backing up my daily, flashing my test builds, then restoring my original setup when done, I don't want to receive any calls or texts on the dev ROM. If I did, they would be saved on the temporary one which would get destroyed when I restore my original. Would the best way be turning on airplane mode in the init scripts, or do the radios start up before them? Pretty much if someone sent me a text while flashing the dev ROM, I want to make sure it isn't possible to receive it until I restore my original copy.
Oh, and I know it would be easy to just cripple the radios, but I would prefer it if I could turn on the radios if I wanted (like auto-airplane mode).
Thanks.
Thanks.
Since flashing the new build, I started getting text messages about new voicemails, while also getting the voicemails themselves. Is there any way to block the sender in the default messaging app?
I only believe it works on sense based roms.
I will say this, we had this issue on the venture.
it's not a specific rom or version that enables this, it just has to be almost 100% stock.
as in, stock dialer (no mods) stock contacts (no mods) ect..ect..and there is a hidden menus apk that seems to be important as well.
I can confirm this on this phone with a bit of research, sense based rom's alone won't do the trick, but if i flash a rooted stock rom, these codes work fine.
i had to do it to reset my msl one time, very very slow network speeds, VM told me to enter those codes not knowing i was running a custom rom...and it didnt work.
I also know this doesn't help much in this instance, but it gives some explaination as to why it doesnt work, and just calls the number.
I am having an issue with MMS, at least with picture messages. If I have data disabled, I do not receive the message at all, and there is no placeholder for one (with a download button) as there was when I was using Sense roms.
Is there a fix for this? Or do I just need to evolve to modern ages and just leave 3G on all the time?
And one more thing: All picture messages that are accompanied by text are displayed as slide shows, complete with play button. I really miss having them both displayed there naturally with no "play" button...
