MArcelloMayhem
So far the best build is 07.02.13 with 07.03.13 Kern update. That's what I've been using for the past 3 weeks.What's the last good build without mic issue?
The WiMax issue was with 7/17/2013. The 7/2 with 7/3 kern update has been solid for me compared to other releases.Will there be an angry bean update to address the mic issue? Didn't the 7-2 release have issues with wimax working, if I remember right?
7/2 with 7/3 kernel is flawless. Been running it since 7/4 no issues whatsoever!
Yes. You just have to go into mobile networks to activate. The indicator in the notification doesn't show when you're connected, but you can see it under mobile networks
I know the team is working really hard to get officially merged into CM, but could we get a quick update for this rom maybe even if just CM upstream. I have an itchy flashing finger![]()
Do you have the 7/3 kernel and have you completed Joe blow's hacks
You can always revert to stock hboot and and stock Rom, then start from scratch. I had to do this once before when cm10 was first released. Also digital high over at xda has a sweet Rom MiuiV5 and I run it on the other evo3d I have
