After you do a reboot, as long as you don't use any app that uses the mic, audio & video should work just fine.
This may sound like a dumb question. Does the phone app qualify?
Are you: Rooted? S-OFF? Using 4EXT (Not REQUIRED, but recommended)?I'm on hboot 1.50. I ran the zip from the Joe blow hacks.
PLEASE NOTE: Phone will NOT WORK after flashing these file! Yes you heard me, now that I have your annotation: do not forget to re-format your cache ( along with delvik ) after the flash. ...
Ok, well it sounds like something much deeper is causing the issue. My advice would be to start over completely fresh.Yeah I did that. And I'm s-off and rooted. I'm back to using SOS M rom right now. Using 4EXT. Should I maybe try smart flash? Any other ics rom with or without sense works.
To save you a headache or two, Team Unlimited stopped supporting Windows so you will need to create an Ubuntu Live CD to run the wire trick for S-OFF now days.
So quick question, more of a survey really, for you guys. What's the most stable release of Angry Bean so far? I've been hearing nothing but problems with the mic in the latest (8-8-13) release. The reason I ask is because I'm still running on the 5-01-13 release which I've been using since release day. I've had little to no problems with that version, except for the occasional data drops which are fixed by toggling airplane on and off. MMS works fine. Heck, everything works fine. Guess that's why I never updated - if it ain't broke don't fix it. Just in the last week or so I've been noticing (maybe imagining) that I'm not getting notified of new texts coming in and figured its time for a new flash, so might as well update. Have there really been enough changes to newer versions to warrant an update or should I just reflash the one I'm using? What's changed in 3 months? What have I been missing out on? What's your daily driver?
Note: I know the ROM has changed hands and I'm using g60's version. This post made with all due respect to Chairshot, I respect and appreciate all the work you've put into this ROM and the Android community. Keep up the good work!
I absolutely agree, however the last time I did an S-OFF, nobody was hosting the files. If you have the files and would like to up them to a host (Dev-Host being my personal favorite due to its speed) myself and I'm sure others will be thankful =)You can still do it with Windows. We've always been able to, and Virgin/HTC hasn't patched anything, so it still works. Download the last version they released for Windows. Just know you just won't have support if you run into trouble. I just did another S-off in Windows less than a month ago using the last version they released for it. Silly to have to install a whole new OS just to run one tool.
1) Factory restore your phone (I'm talking about returning it to TRUE factory default). I've extracted the latest RUU from the .exe for this phone (and this phone (Virgin Mobile HTC Evo V 4G (CDMA)) ONLY!) and created a flashable zip (much like the joe_blow hacks). I'm hosting a copy on MEGA which you can download from HERE. THIS WILL WIPE EVERYTHING, ROM, FILES, ROOT, ETC. I would recommend backing up your Micro SD Card (MSC) as well. Once you're ready, place the file on the root of your MSC, then boot into bootloader and follow the directions like if you were flashing the joe_blow hacks. There will be one reboot required (when prompted) during the process. Once everything is done flashing, you will have a phone as if it was just sent from the VM warehouse (software wise, it won't fix scratches, dings, etc. ;P)
2) Follow the fine guide HERE to root, unlock, etc. again.
If you have any other questions feel free to ask =) Hope that helps.
So quick shameless promotion: MEGA is the successor to Megaupload made by Kim Dotcom. MEGA is geared at high security and data protection so you have to leave the window open while the file downloads "in the background" completely, then once the download has been verified as completely downloaded by the server, it'll push the normal save dialogue. The file should be 432.8 MB (or within a few MB of that; I'm on a Mac, might show different on different machines depending on different factors).Quick question. When the file finishes downloading is it supposed to be only 120 some megabytes? Cuz at the download screen it says its over 400
File supposed to be 151.33 MB; it tells u on the page.Quick question. When the file finishes downloading is it supposed to be only 120 some megabytes? Cuz at the download screen it says its over 400
