I've done Dirty Flashes with Angry Bean & havent had an issue. Except for the bugs that come with the ROMs.Hey, been a while since I have updated (since around april) and was wondering if with the current version would I need to wipe clean to update or can I dirty flash? I've accumulated a lot of data since last updating and would like to avoid a wipe if possible. Don't really trust Titanium Backup either.
Build 07.02.13 with 07.03.13 Kern update. Doing the Kernel update is like Flashing. Just make sure u do 07.02 first, and after reboot do 07.03.Sweet. Which version are you using? And is there a different process to update the kernel?
Build 07.02.13 with 07.03.13 Kern update. Doing the Kernel update is like Flashing. Just make sure u do 07.02 first, and after reboot 07.03.
Go to Vmobi BrowserI cannot find the new kernel after flashing the update. With the 07.02.13 and 07.03.13
That's a new issue, never came across with any ROM or ROM updates. Only thing I can suggest is RUU & see if happens with Stock ROM.The first is that the screen is detecting multiple touches even when I am not touching the screen. Actually, visual feedback shows 1 or more dots indicating touches but really the screen just freezes. I've wiped and reinstalled everything a couple times... and I do have these currently installed :
cm-10.1-20130702.zip 150.57 MB 02.07.13 22:32:30
cm-1angrykern_07.03.2013.zip 3.75 MB 03.07.13 22:02:09
I did experience Static-Like Lines when Recording Video. Hopefully [maybe] an update will fix that issue.Secondly recording video has these rough lines flashing and stays in the video and i was wondering if anyone was having any issues with that.
So I switched to this ROM a couple months ago and I have had some issues with in-call audio. Sometimes when I make or receive phone calls the audio in completely inaudible and sounds like a garbled mess. I will answer a call and not be able to hear anything at all. Also, I had one call where the other person could not hear me, though I do not know that was an issue with my phone because it only happened once.
Has anyone else had issues with this ROM during phone calls? I do not make phone calls frequently enough for this to be a big problem (I've lived with it for a couple months) but I do need to figure it out. I think I will try to reinstall the ROM today and see if that helps.
Thanks for any help people can provide.
