my SMS is not working on the latest build.. fresh install- VM
Sorry, there was a problem with my VM account.It's been working perfect for me. Did you do a full wipe of all partitions except SD?
hey g60, is there any way you could possibly make a mirror of gapps? Im getting horrendous speeds on goo im
How slow are we talking? I just checked goo.im and downloaded in 4-5 minutes...
Anyway, I put it on my dropbox: https://dl.dropbox.com/u/100923173/gapps-jb-20130301-signed.zip
One of the features that I missed the most on the stock ROM or midnight ROM is the internet pass thru, is that something that can be incorporated into this ROM?
Great job by the way i prefer this ROM over Wild for the night.
An observation: none of the three JB ROMs I've tried have either a 4G/WiMax signal indicator in the status bar or a 4G toggle available for the Quick Settings Panel.
Anyone care to help/illuminate me?
Thanks!
, just know it's on the list to be fixed!
long time fan
Known Bugs or Irritations
Repo Updates
Visual Voice-mail
4g Toggle Icon - Tile
4g Signal Icon
1x10^6 thanks! Don't mean to pile on, but I've noticed there's another 4G status issue: the Power Widget 4G icon's on/off status doesn't seemed to be linked to the actual WiMAX status. Toggling the Power Widget icon on or off has no effect on whether WiMAX is on or off.
There's no link the other way around, either... enabling or disabling WiMAX from the WiMAX Settings page has no effect on the Power Widget icon's on/off state. Basically, the icon only serves as a long-press shortcut for WiMAX settings... which I *do* appreciate as an alternative to going via the main settings window.
)I'm running a clean install. No SMS still.
