agismaniax
It's work with 3MB cache partition. Unable to authenticate with google service with 2MB cache.
) - I downloaded Fastboot Commander in preparation...hi all and a very good evening to you.
I've had my Desire for ages (year and a half) and pretty recently took a big step (for a phone / linux noob) and rooted.
It didn't go smoothly but I got there in the end with stacks of help from a dude on the Revolutionary IRC (many thanks Dan0man, couldn't have done it without your intervention, just in case you are conceivably reading this thread).
I moved from the HTC 'official' gingerbread release:
BRAVO PVT3 SHIP S-ON
HBOOT-1.02.0001
MICROP-051d
TOUCH PANEL-SYMW0101
RADIO-5.17.05.23
Jul 22 2011, 16:19:16
via Revolutionary to:
BRAVO PVT3 SHIP S-OFF
HBOOT-6.93.1002
MICROP-051d
RADIO-5.17.05.23
Aug 10 2012, 17:52:18
So... I've done heaps of reading, including all 33 pages of this thread and think I've got an idea of what's going on.
I am aware that this ROM is bare-bones, so have tried to prepare myself for a non-SENSE, minimalist experience
However, I'd be very grateful for any tips / headsups, people could offer me.
I'm afraid this post is a bit stream of consciousness, so might not be too coherent... but what launcher, if any, does dGB use?
Also, I read, on this page and elsewhere about the size of cache and it impacting on the installation of large apps, games, etc. Is there some trickery, which dGB uses to circumvent this issue?
What about recovery? I've got whichever version of CWM that came with Revolutionary 4.0.1.4 but I think I read SURoot talking about another, which was "infinitely better" (found it: "4EXT" post 1315 and below)
Talking of recovery, should I use recovery (e.g. CWM) to format system, cache & data? I'm pretty sure Rastaman advocates Fastboot (but perhaps he just can't function without the monochrome of a command prompt) - I downloaded Fastboot Commander in preparation...
Ah... also... I checked the MD5 for the 65MB HBOOT file but couldn't see the MD5 for the ROM, so haven't been able to validate that. Am I being blind?
Kernels: I believe one is packaged with the ROM. Presumably this is the recommended one? What would I be getting with the others ones? I think there are 4 on the dGB google sites page...
I also thought, as I've seen it recommended, to maybe do a half-way house and just install the ROM (without adjusting the HBOOT)? Any reason why not? I believe I can install the HBOOT later anyway (to fix the partitions)...
Oh yes... backing up. I did a nandroid backup after S-OFF and have literally just run as full a backup as possible using MyBackupPro (as that's the app I have). Is there a significant need to use Titanium? I was tempted to do a fresh install of all my apps anyway, to compliment my sparkly new ROM, so don't have a huge need to recover my existing apps from backup. I also don't know what crap may have been saved during the backup process...
Can't think of much else. Apologies if I've been too verbose.
All the best,
Gary
Launcher2, which is the basic, stock GB launcher. But it's really there just so that you have a launcher when you first install (you will find it very hard to use a phone without a launcher!). Most people then install a launcher of their own choice.I'm afraid this post is a bit stream of consciousness, so might not be too coherent... but what launcher, if any, does dGB use?
Yes, there is (a temporary RAM disc IIRC). The cache isn't a problem.Also, I read, on this page and elsewhere about the size of cache and it impacting on the installation of large apps, games, etc. Is there some trickery, which dGB uses to circumvent this issue?
The most stable CWM for the Desire is 2.5.0.7. But a lot of us have moved to 4EXT Touch now, and I can strongly recommend it. Being S-Off it's easy for you to change - just install the 4EXT app, and let it flash the recovery. It can read nandroid backups made with CWM too.What about recovery? I've got whichever version of CWM that came with Revolutionary 4.0.1.4 but I think I read SURoot talking about another, which was "infinitely better" (found it: "4EXT" post 1315 and below)
If you need to format those, I'd usually do it from recovery. But I assume you're specifically referring to the recipe for changing hboot, in which case you would be using fastboot commands anyway, and it will be easier that way.Talking of recovery, should I use recovery (e.g. CWM) to format system, cache & data? I'm pretty sure Rastaman advocates Fastboot (but perhaps he just can't function without the monochrome of a command prompt) - I downloaded Fastboot Commander in preparation...
Probably not. It's a lot less critical for a ROM than a hboot. Bad ROM download, just download and flash again. Flash a bad hboot and you may lose the ability to flash anything else (i.e. a hard brick). So checking the integrity of the hboot is absolutely essential.Ah... also... I checked the MD5 for the 65MB HBOOT file but couldn't see the MD5 for the ROM, so haven't been able to validate that. Am I being blind?
I'd just stick with the one it comes with. Only think of flashing something else if you have a problem.Kernels: I believe one is packaged with the ROM. Presumably this is the recommended one? What would I be getting with the others ones? I think there are 4 on the dGB google sites page...
If you flash the ROM first then (a) you are only changing one thing at a time, rather than 2, and (b) if there is a problem with the ROM and you still have the original hboot you can just restore your nandroid (you did take a nandroid before flashing the ROM!). If you change hboot first you can't restore the nandroid without changing the hboot back, because no other ROM will fit.I also thought, as I've seen it recommended, to maybe do a half-way house and just install the ROM (without adjusting the HBOOT)? Any reason why not? I believe I can install the HBOOT later anyway (to fix the partitions)...
Most of us reckon Ti is a more fully-featured backup app for root users.Oh yes... backing up. I did a nandroid backup after S-OFF and have literally just run as full a backup as possible using MyBackupPro (as that's the app I have). Is there a significant need to use Titanium? I was tempted to do a fresh install of all my apps anyway, to compliment my sparkly new ROM, so don't have a huge need to recover my existing apps from backup. I also don't know what crap may have been saved during the backup process...
Believe me, I can out-verbose you!Can't think of much else. Apologies if I've been too verbose.
:fight:
I'll try to address in order. Apologies if I miss anything.
dGB uses by default, Launcher2 (the Standard Launcher from 2.1/2.2/2.3 Vanilla Android) Howeverr I recommend using Go Launcher.
dGB employs an expandable RAM disk to accommodate downloads. This means a virtual disk in RAM is created when a download starts and expands to a size that the app can fit in. Once the app is installed, the RAM disk is destoyed.
Yup, Use of 4EXT is hugely recommended
Rastaman generally uses fastboot to format as he likes to make his instrtuctions universal. AmonRA recovery does not have this option. Formatting with 4EXT would be fine for NAND memory (Not necessarily SD cards though).
Theres no Md5 for the ROM. Hboot flashes, if corrupt will brick your phone so these are provided as a precautionary measure. This isnt the case with ROMs so there just isn't one
All roms are packaged with a kernel. The kernel is the beating heart. Nothing works without it. The packaged one IMHO is the best. The rest are variations (AXI, BFS etc). The packaged one is AXI CFS. Have a read of my kernel info thread (Via my signature) for the differences.
Try the ROM alone without hboot first as its easier to get out of. You mentioned bare-bones non-sense earlier. There are far fewer bones here than any other bare-bones non-sense ROM, so be aware its not to everyones tastes. I do usually recommend people try other AOSP ROMS before this as often "Wheres this function? Wheres that function?" is the same across all AOSP roms. And sometimes not. Its nice though, when people know what an AOSP rom is rather than just thinking I cut stuff out that I didnt
You dont NEED titanium. certainly not for this job. Sometimes its nice if you need to restore an entire load of apps and data as the data often doesn't carry over well in MB. But in Ti, that can be a problem too.
With My Backup, be careful not to restore contacts or calendars if these are google though as you'll end up with duplicates.
Hope this helps.
Thanks Nicka. Great tip. Reassuringly (for me) I made both a manual note of my APNs (cos for some reason they differ just slightly to O2's online ones).You will need to atleast make a note of you APN details or use APN Back up as there are no APNs included in this ROM.
Unless this is departing from the thread too much, what launcher do you use?Launcher2, which is the basic, stock GB launcher. But it's really there just so that you have a launcher when you first install (you will find it very hard to use a phone without a launcher!). Most people then install a launcher of their own choice.
I think I'll stick with CWM (falling in line with your comment about 1 change at a time) but when you say install... actually, don't worry. Just did the easy (and non-lazy) thing and googled 4EXT installation. Simple when it's an APK. I did just wonder whether it might be a .zip that I had to run from recovery..The most stable CWM for the Desire is 2.5.0.7. But a lot of us have moved to 4EXT Touch now, and I can strongly recommend it. Being S-Off it's easy for you to change - just install the 4EXT app, and let it flash the recovery. It can read nandroid backups made with CWM too.
Can't remember where I found out about this - probably in a fastboot FAQ... but I found a recommendation for it. It's a command line interface for Fastboot anyway. So if you don't use it, what do you use instead?I don't know Fastboot Commander myself - command line for me too![]()
In regard to reversing HBOOT (if for some bizarre reason I needed to leave dGB), I guess I could run Revolutionary again?So yeah, ROM first, check all OK, then take a new nandroid and change hboot.
. You can also mount the sd over usb when in recovery mode.Yes, you flash ROMs from recovery, not via fastboot.
Copy to sd, then in recovery select the install zip from SD option. You've already wiped everything, so no need to worry about that. I assume you have a nandroid, 'cos it's too late now if not. You can also mount the sd over usb when in recovery mode.
Do read the faqs linked from the All Things Root Guide sticky - I'm sure there must be a description of flashing a ROM in there.
ooooooooo...
it's all shiny and pretty![]()
ha. Magpie!
ty SUroot for this.
Gazzawazza is not the first to ask this recently but it is there in Suroot's FAQ http://androidforums.com/desire-all-things-root/221212-faq-rooting-updated-7th-april-2012-a.html#26
) and the spellcheck is pants.
I've been doing a fair amount of playing with the keyboard and been using Market reasonably too (to browse for keyboards / reading app reviews, etc) and WiFi's been on all the time.
