daysineuropa79
anyone got the 65mb Hboot as a .zip to flash from sd card rather than the .img ?
Yes, that's the stock hboot. Like Nicka has said, you need to s-off and fastboot flash the dgb hboot (.img file)
Nandroid backup from recovery
fastboot flash the new hboot
nandroid restore from recovery
Continue flashing this morning....I had no problem rinning fastboot , but stuck on flashing hboot - tried bot 60MB and 65MB versions but keep receiving :
E:\PROGRA~1\Android\android-sdk\platform-tools>fastboot flash boot bravo_alphaspl_dgb65.img
sending 'boot' (512 KB)...
OKAY [ 0.094s]
writing 'boot'...
FAILED (remote: image error! (BootMagic check fail))
finished. total time: 0.094s
Ideas ?
When I install dGB will it automatically change the MTD partition sizes so i have the 350MB /data and the others or do I have to manually change that by using the alpharev partition tables?.I want to change these sizes so I can take benefit of this ROM..The root memory faq, linked from the All Things Root Guide sticky post, should explain the basics. Beware that there's a procedure called "custom mtd" which is different from the custom hboot, so try not to get these confused (custom mtd is slightly more flexible, custom hboot easier).
I assume you want to try dGB, as you'd need a different hboot for Redux. The ext partition won't matter, as dGB will just ignore it.
What I'd recommend is:
* S-Off
* Install dGB.
* Take a nandroid
* Install hboot
* Restore nandroid
Installing the hboot is just a fastboot flash (see adb and fastboot faq). Alpharev.nl also has instructions for changing hboot on their site.
Always check the md5 code of a hboot before flashing - a bad download is unlikely, but could be fatal to the phone.
So there are 2 methods for this then.It won't automatically change the mtd or hboot you need to do this manually. Use fastboot for flashing the revised hboot which you can get from the dgb mini site but as hadron said check the md5 to ensure the download is right. Have fun oh and don't forget nandroid backup first ;-)
thanks..all worked fine with the flash and hboot...now to experiment..Yes there are two methods, but i have always used the hboot, (didnt fancy getting caught up with custom MTD's)
as for the MD5, you use this to check you dont have a corrupt download, if you go to the all things root sticky in the useful software / downloads section there is an md5 checker.
if you run this you can check that your download is not corrupt.
your steps seem correct but just to make sure here is how i understand it.
always take a nandroid of the current rom you are running as if this goes qrong you can always re-flash the stock hboot and flash the nandroid to get your phone working again.
1). do all the wipes and flash dgb rom.
2). boot into recovery and take a nandroid.
3). boot into fastboot and flash the dgb hboot, you should notice the top pink lettering change to su-dgb 60 / 65 or something similar, you may need to reboot the bootloader via fastboot to get the change to show.
4). reboot to recovery and either reflash the rom or run the nandroid (dgb one)
if you are flashing the hboot i would not worry about the MTD stuff it will only confuse you, (as it did me)
hope this helps and enjoy
