[ROM] aospCMod | AOSP 2.3.4 / CM7 (Gingerbread) [05/23/11]
DonB
♡ Truth, Justice and the American Way !! ♡ ™
Moderator
New Release Report your findings
Full wipe for flashing
CWM Recovery
Wipe data/Factory Reset
Wipe cache partition
Advance/Wipe Davlik cache
Go to Mounts and Storage
Partitions Menu/Format Boot
Partition Menu/Format System
Partition Menu/Format data
Partition Menu/Format Cache
"Do Not Format SD Card"
Thanks to AOSP and his crew
May 23-2011 Release
aospCMod-HEROC-20110523-signed.zip
MD5SUM: 7516670815622f9f0d1cab66d7148224
gapps-gb-20110325-signed.zip
MD5: 4cbe712c0bde778fb7f2d32d32b57dd8
http://bit.ly/etmJrx
Changelog
CLICK for ROM Info
May 23-2011 Release
Changelog
What Works,
READ ME
Posted by a member @ XDA
So what I have found not to work and works:
Works:
Wifi
Mms (Send)
Bluetooth (not fully tested)
Calls
Texts
Data
What does not:
GPS
Camera
USB tether
Info and app restore like froyo had
MMS (receive)
Gmail
If you gmail isn't working, search "gmail" in the market, there is an update and installing that update fixes it for ya
[ROM][GPL][UNSTABLE] aospGBMod ALPHA | AOSP 2.3.1 (Gingerbread) [12/22/2010]
Use at your own risk, this is unstable but something for you to play with
aospGBMod-ALPHA-signed.zip
MD5: 329981ec518befe6f2ee66bf09f48404
From Zenulator
cm-7.0 RC0 gingerbread for gsm hero
Multiupload.com - upload your files to multiple file hosting sites!
mdpi gingerbread google apps
If you are going to throw the zen CM7 rom in there make sure you flash one of Deca's kernels in there. Flash rom, flash gapps, flash a Deca kernel;)
Is Zen's Working better than Aosp.
I tried to flash last night, not able to:( I forget what the error said in recovery but something to do with Hero. Maybe clockworkmod recovery stopped from installing because it is for a GSM Hero not CDMA:confused::confused:
Oh well, just as soon as I restored back, aosp put the alpha build:D:D:D
Original Post Edited New release Christmas day, enjoy and report your findings. ;)
New release posted in original post Rom and Gapps Dec 28 Enjoy and report your findings here ;)
0.1.2 is up with working gps, usb storage, usb tethering and 1228 gapps can be flashed after rom from recovery no need for rebooting now happy holidays
aospGBMod-v0.1.2-signed.zip
MD5: 95d3a4c6ea60f59de5de2b51f08cc035
gapps-mdpi-20101228-signed.zip
MD5: a74496be5ace97bad32011214aa5e3ee
OK - Fixes
G-mail bug is fixed and Sensors are fixed.
still no camera or native Wifi hotspot.
Good smooth ROM - using it as my daily -
Funny....needed the barcode scanner last night....no camerallll DOH
What is recovery clockwork? Is this something that we should flash for it to work properly? Also why 1.5, 1.6, 1.7 all within days of each other? I am really excited to flash 1.7 now...:):D
just tryed flashing 1.7 and just kept getting the "HTC quietly brilliant" screen popping up and going back to a blank screen. I let it go for almost a half hour and got nothing. did a full wipe and cache before. am i missing something?
I wiped, flashed, booted... I get to the Cyanogenmod 7 start up screen and it just loops. It did this with both the 1.6 and 1.7 version. I am lost on what I am missing.
What recovery are you using, hopefully clockworkmod ;-) You will have to wipe in the partitions menu. Boot, data, cache and system. Do not wipe sd, obviously! Then flash rom and gapps. Reboot
What recovery are you using? If clockworkmod, do what I said above!
im using clockworkmod. I did not wipe the partitions. that sounds like the issue. ill give it a shot.
When i do wipe the partitions, the partitions are still saved in my nandroid if i decide to go back to aosp froyo, correct?
Yes, no troubles here nandroiding back
