Circle Battery Mod steps for MetaMorph
Make a backup before you install this incase something goes wrong as I am not responsible for what you do to your phone. I have tested/installed this on my phone several times with no problems though.
Credit to TheLynxy on XDA for making the images
1)Install MetaMorph from the market if you dont already have it (its free)
2)Download the
Circle_Battery.zip and place it in the "AndroidThemes" folder on your SD card. If you dont have that folder on your SD card, make it, and CAPS MATTER
3)Open MetaMorph app and press "start checks"
4)press "Unzip/Extract new theme" then press "Circle_Battery.zip"
the zip will extract then it will bump you out of metamorph (idk why, mines just doing it, but no biggie)
5)go back into metamorph and press start checks again if it pops up
6)press pick existing theme then press the "Circle_Battery" folder then press the next Circle_Battery folder
7)press Circle_Battery.xml (should have a metamorph symbol next to it) when the popup comes up that says Circle Battery v1 press the close button
8)Press "Apply all!" on the bottom right then press "Continue?"
Your phone will now install the circle battery charge and discharge images and will ask if you want to reboot now. Press yes.
Your phone should reboot and install the Circle Battery images that go from blue>green>yellow>orange>red
Enjoy
