UPEngineer
Hey guys, did you get the Market/Gmail FC's figured out? I'm pretty sure it's because I updated all the Gapps to the latest versions, but if you came frome 1.2.1, they were downloaded from the market and are on /data
What you end up with is 2 copies of the same thing, and that's confusing
I've gone ahead and updated the instructions for 1.2.1 users that want to keep data, that they should just uninstall updates to all Gapps before flashing and they should be fine.
Fab,
I SBF'd back to .320 after factory reset and getting ready to apply the 1.3.
I was on 1.2.1 before I SBF'd.
I went into manage applications and looked under GMail, Market, etc. and I do not have any uninstall updates. I do have some cache and data? Should I clear that or leave that alone?
If I continue to have problems, can we go into /data and delete one of the duplicates or is it more to it than that?
I havent experienced the GMail force close yet, but I have for the Market. There is really no rhyme or reason to when it happens really.
I gotta say your roms are freakin awesome, BTW. The way a phone should be!!!!!
Very smooth. No problems. I really don't think this needs a theme. HowEVER, in a perfect world, I'd love a 10% battery mod, the REVO type lock and that revo mod app where the guy replaced verizon with Apex Revolution.
