Root [ROM] ApeX 1.3.1 for Droid X - Running, running, as fast as it can (12/16/10)
Please read the 2nd post in this thread.
Hey Fab, I read that post before I asked... neither of those are the KB I'm looking for. I'm looking for the big one that comes stock on the X from Moto...
I've tried all three of those options and neither of them are what I'm looking for...
Unless I'm missing something... :confused:
Yes, you're forgetting to switch keyboards back to multitouch after the script (it automatically changes to Swype since it deletes the old keyboard for a moment)
run:
su
keyboard -wmt
After it reboots, go into any app with a text input, press and hold on the input, switch inputs back to multitouch keyboard.
I'm about to update that post with the additional info, thanks for pointing that out.
I think in 1.2.1 the stock keyboard was left in it. I just used WJD's black keyboard mod zip to change it to black. i could be wrong though. All I know is I like the normal type keyboards myself. I was on Rubix and couldn't get use to the different keyboard......
Not really sure about the keyboards that are with the zip for this rom cause i am in love with the GB keyboard..
Nevermind my gibberish, Fab answered you, lol.....
Thanks guys! Totally didn't remember that switch AT ALL.
AWESOME!!
yeah, it's just defined in framework-res.apk, but I used the .340 version in 1.3.0
I kind of like it because I use the lock screen music controls a lot, and this gives it a lot more space. Previously, they were right up on the sliders.
I definitely prefer the lock slider lower. Is there any way to keep the lock slider lower on NexTheme?
Awesome job by the way!!!
Fab,
I might have found a bug or maybe not a bug but an anomoly.
I have tried everything from going to stock to wiping/clearing/etc. and I can still reproduce it 100% of the time.
I can say that it did not do this with Apex 1.2.1 at all but is in 1.3
If I use any of the app 2 sd applications, whenever I click on the appname and then move to sd card, I get an error "Failed to move application". But if I click on move to sd card again, it works. It is just annoying to have to press it twice along with another press to get rid of the dialog.
Any ideas what could be causing this?
Other than that, I got my market and gmail FC fixed....
Fab,
I just tried to move a few apps and they worked on the first try.
Fab,
Thank you so much! From 928 Black Glass, to Rubix, to Tranquility to now Apex 1.3. I can honestly say this is the best Rom/Theme i've ever had on my X. Wow! I'm blown away by the quality of this rom and all the Gbread touches. Keep up the great work, donation on the way!
Same here. UPEngineer, can you confirm that you are on Market V2.12?
Also, how are you recreating this error. Like, do you restore your apps with TiBu, then try to move them, or are you downloading the same app fresh from the market each time, and then moving it?
And lastly, I do quite the opposite. I move all my apps INTO internal storage. We have 8gb people, and it ain't doing anything else but store apps. Not to mention it's quite a bit faster than the microSD.
Sort of a newbie here...but does anyone else have issues with media apps? My music player doesn't recognize files and the pandora/siriusxm can't connect. Thanks!
I keep all mine in the internal storage, like you said, it's only for apps.
i made some 10% battery icons for you guys. you should be able to use ninjamorph to change them or fab could make an update.zip for them if he likes them.
hard to see some of the numbers now but in the black bar they will be fine.
  • GB_Battery_THIS_IS_NOT_AN_UPDATE_ZIP.zip
quick question. why is the background for the lock screen different from home screen? Is there any way to fix this?
SBF'd, updated to .340 and upgraded to ApeX 1.3.0 this morning. As usual, amazing work, Fab. Not a single issue to speak of on my end. Thanks for the advice via PM yesterday as well. Between this and my extended battery I received in the mail today, the X seems brand new to me again.
whats the correct way to install the new update? i have the 2.3.15 running apex 1.0.2.2. OTA update failed to install. anyone have the file? i want ApeX 1.3!
Are the transition animations configurable? I dug around in ADW and didn't find it and didn't see anything in first post to indicate it could be changed through the scripts.
edit: loaded up launcher pro and same transitions, so they must be in the ROM :)
