Root [ROM][BETA][4.1.2] AOKP Jelly Bean for Virgin Mobile and Sprint 12/30/2013
Just a few things:
Is there a way to remove AOKP statistics from the status bar? It pops back up about 2 mins after clearing it.
Also I thought 4.1 came with a swype style keyboard as part of the OS.
Do you need to use an app for tethering not the built-in one?
Try tapping on the AOKP stats and checking disable and enable.
and the keyboard swype like feature is in 4.2+ but google released it as a standalone app in the playstore called Google Keyboard.
Just a few things:
You can get the apk and libs from my mod zip should you not want to flash the entire package.
Anyone else having issues with toggling air plane mode back and forth sometimes it won't nd u have to do a reboot
so as soon as you posted this rom, i put it on my phone and it ran likea champ. then stark made the mod, and hooked us up with the camera, well long story short, i showed the wife, and she finally decided to let me mod her OE too. well after that we both had troubles using wifi at the same time. so i checked and both our phones have the same mac address and our router assigned the same I.P address. i am going to look for something that alters my mac address for the time being but thought u should know whats what with it. thnx for the rom, really am digging it.
ok, after some research (google =p) i found enough to lead me in the right direction.
found this file with a hardcoded mac address (probably the same for all devices running this rom)
in /system/etc/firmware/wlan/volans/WCN1314_qcom_cfg.ini
i changed the mac address there was 2 spots, and rebooted phone, ip address changed and mac adress changed, running like a champ.
if anyone else has this issue, that should fix till it can be added to the rom, which i have no experience doing. i'll leave that up to the devs =p
Is that what your edited ini file looks like? If not post the changes so everyone can benefit. ;)
[HIGH]# This file allows user to override the factory
# defaults for the WLAN Driver
# Enable IMPS or not
gEnableImps=1
# Enable/Disable Idle Scan
gEnableIdleScan=0
# Increase sleep duration (seconds) during IMPS
gImpsModSleepTime=600
# Enable BMPS or not
gEnableBmps=1
# Enable suspend or not
# 1: Enable standby, 2: Enable Deep sleep, 3: Enable Mcast/Bcast Filter
gEnableSuspend=3
# Phy Mode (auto, b, g, n, etc)
gDot11Mode=0
# Handoff Enable(1) Disable(0)
gEnableHandoff=0
# CSR Roaming Enable(1) Disable(0)
gRoamingTime=0
# STA MAC Address - This will be used until NV items are in place
# Each byte of MAC address is represented in Hex format as XX
NetworkAddress=000AF58989FF *I EDITED THIS HERE*
# UAPSD service interval for VO,VI, BE, BK traffic
InfraUapsdVoSrvIntv=0
InfraUapsdViSrvIntv=0
InfraUapsdBeSrvIntv=0
InfraUapsdBkSrvIntv=0
# Delay triggerframe interval
DelayedTriggerFrmInt=18000
# Disable RSSI FW filtering
gEnableFWRssiMonitoring=0
# Make 1x1 the default antenna configuration
gNumRxAnt=1
# Beacon filtering frequency (unit in beacon intervals)
gNthBeaconFilter=50
# Enable WAPI or not
# WAPIIsEnabled=0
# Flags to filter Mcast abd Bcast RX packets.
# Value 0: No filtering, 1: Filter all Multicast.
# 2: Filter all Broadcast. 3: Filter all Mcast abd Bcast
McastBcastFilter=3
#Flag to enable HostARPOffload feature or not
hostArpOffload=1
gEnableLogp=1
#SoftAP Related Parameters
# AP MAc addr
gAPMacAddr=000AF58989EF *I EDITED THIS HERE*
# 802.11n Protection flag
gEnableApProt=1
#Enable OBSS protection
gEnableApOBSSProt=0
#Enable/Disable UAPSD for SoftAP
gEnableApUapsd=1
# Fixed Rate
gFixedRate=0
# Maximum Tx power
# gTxPowerCap=30
# Fragmentation Threshold
# gFragmentationThreshold=2346
# RTS threshold
RTSThreshold=2347
# Intra-BSS forward
gDisableIntraBssFwd=0
# WMM Enable/Disable
WmmIsEnabled=0
# 802.11d support
g11dSupportEnabled=1
# Country code
#gAPCntryCode=USI
#Short Guard Interval Enable/disable
gShortGI20Mhz=1
#Auto Shutdown Value in seconds. A value of 0 means Auto shutoff is disabled
gAPAutoShutOff=0
# Listen Energy Detect Mode Configuration
# Valid values 0-128
# 128 means disable Energy Detect feature
# 0-9 are threshold code and 7 is recommended value from system if feature is to be enabled.
# 10-128 are reserved.
# The EDET threshold mapping is as follows in 3dB step:
# 0 = -60 dBm
# 1 = -63 dBm
# 2 = -66 dBm
# 7 = -81 dBm
# 8 = -84 dBm
# 9 = -87 dBm
# Note: Any of these settings are valid. Setting 0 would yield the highest power saving (in a noisy environment) at the cost of more range. The range impact is approximately #calculated as:
# Range Loss (dB) = EDET threshold level (dBm) + 97 dBm.
gEnablePhyAgcListenMode=128
# LGE_CHANGE_S, real-wifi@lge.com, change gDataInactivityTimeout 200
gDataInactivityTimeout=200
gBmpsModListenInterval = 65535
# LGE_CHANGE_E, real-wifi@lge.com, change gDataInactivityTimeout 200
END
# Note: Configuration parser would not read anything past the END marker
[/HIGH]
the places i edited are marked in the file
I'm still getting weird data. It sometimes just decides to go grey on me. And other times its blue but I have no connection.
Yeah I'm having intermittent data issues. Going to pull some radio logs and suggest everyone having the issue does the same.
Its strange. I still get texts, and some apps work, and some don't. Sometimes none of the apps have Data connection. I did a clean reflash and it still persists.
all in al l works fine for me.. txts are fine, Only thing iv run into is facebook running slow, and when i connect to bluetooth audio is does not play through bluetooth, it connects and pairs fine but always plays through phone speaker. other then that i like the progress onthis, . thanks .. smoke oms hash oil now..
Can I ask why you always have the screenshots in your original posts of your ROM threads just say "Coming soon." Phenomx? Lol you should add some so ppl know what Aokp looks like before using it. :)
Yeah I'll get some up soon.
My phone has slowly become unusable outside my house with the data issue. Today, i have completely no data. Works for a minute after reboot, then stops. I'm gonna have to switch back to ICS build
Is anyone else having trouble with the gallery? I can only view photos and videos I've taken, and every time I play a video I took it says "sorry, this video cannot be played". It won't work.... I've tried flashing several times
