Root [ROM][BETA][4.1.2] AOKP Jelly Bean for Virgin Mobile and Sprint 12/30/2013
One thing I did notice, is that after a reboot, the governor/IO settings revert back to stock. I have mine set @ 1305/noop/smartassV2, after a reboot it goes to 1024/cfq/ondemand, and the toggle is set on "set at boot".
Just an observation, other than that, this is the greatest ROM for this phone so far. Thank you sir. :D
I've noticed that when the phone sleeps, wifi turns off and you have to toggle it off and on to get it to turn back on.
Its a neat ROM but have you given any thought to PA or SlimBean? :)
Thing is that another devolper is working on the rom and wants me to work on it at the same time so we can share fixes and what not. I'd do PA or SlimBean also but I'm running out of space and the only way to make space is get rid of the ICS sources.
I'd love to see Chameleon OS ported to the OE, also just for derps:
Would certainly like to see Chameleon OS on the Optimus Elite.
Have it currently running on KFHD and it's fairly smooth for being an unsupported device.
Thanks phenomx4, especially for all the work on AOKP.
My wish list for AOKP ....lol here we go...
Center lock screen option from CM10
Hot boot option from CM9
Status bar transparency options from CM9
Offline Voice recognition from 4.2
That is all lol. :D
Only problem I'm having is the SD card not mounting properly. Any time I try to do so in the settings, after navigation away from that screen, it results in a freeze.
Love your ROM's Phenom! Was using ICS, but had the audio skipping issues with it, so I decided to give this JB one a try.
Only critical issues I have are ones that were already reported; Bluetooth (Bluetooth syncs to my sports headset no problem, but Bluetooth playback occurs over speakerphone only), and the intermittent mobile data outages (stops working when phone is left idle after awhile; quick workaround I found is to go to mobile data settings, and uncheck/recheck the "data enabled" box twice [airplane mode toggle doesn't seem to fix it]).
Keep up the great work! Sure you'll have these bugs worked out in no time.
Maybe someone can help? I just changed my number and the phone displays my old number. ##Virgin# does not work on our phones so we have to use the activation app. But that does not work on this rom??? Any other ways to change this?
Did you reboot after the number change?
