Root [ROM][BETA][4.1.2] AOKP Jelly Bean for Virgin Mobile and Sprint 12/30/2013
So I'm absolutely in love with this ROM, hands down the smoothest ROM I've ever tried with this phone, cm10 included. The only issue I've ever had was with some sd card mounting error that resulted in a boot loop, but testboot triple fixed that and another issue with the governor settings reverting. The only thing right now is that my contact names and picture don't always show up when calling. I'm not sure if it's too much to ask for an official update for this ROM, but I'm sure the rest of the community would also appreciate it :D
Updated. Let me know how it runs.
some things are still being worked on such as ril and media.
I'll have to build CM10 later because I have to go but It should be later today.
Can the current image be flashed without flashing Gapps if phone already has the AOKP ROM or does Gapps need to be flashed as well?
You need to flash gapps again. The backup function isn't working properly yet.
umm phenomx4 i accidentally deleted my calender app using titanium backup. I meant to get rid of the email app but i wasn't paying attention and deleted the calender. Is there a way to get it back. Also could you post a download to the cyanogenmod filemanager included in cm10. The one i downloaded is missing alot of features.
The rom is great so for still wish there was a way to use lockscreen targets with a lock screen other than the slide lockscreen,though.
Get the apk from the zip.
Phenomx4, pardon the noon question, but what's the difference between CM10 and this version wrt the Elite? Thx.
Aokp has much more features and customization than cm10. I can't really explain but I do recommend trying both out and see which one you like.
install when wfine.. seems faster. .thanks you for the rom and work.. anyway to get wifi tethering to work on this phone? iv tried everyhting, ... tried wifi teather for root, foxfi.. and no dice.. Foxfi cannot start wifi, Wifitether root says its on.. there is no wifi icon. and 3g is running. but i cannot see the phone.. i cannot see or connect to the phone from another device. anyone get wifi tether working on this rom
I haven't had service in 3 months and about to be going on 4 so I can't test things like Phone,MMS, and data but I'll check out the push notification.
Yeah I still have one for testing purposes. Things that'd be a priority before you move on would definitely be Notifications, MMS, ril, Bluetooth. NFC tags etc are a optional feature imo. I'd just go for functionality. Not be concerned with frivolous things like cosmetics or extra lock screen options, animations etc. Those few things mentioned would make this a stable daily driver with all core functions in play. :D
