starkraving
Android Expert
The 3g issues is a known problem...personally from reading a lot I'm sure it is a issue with the RIL and the Radio software/hardware of this device. I'm sure Phenom is looking into it.
Did you guys have the same data problems in stock ROM?
So this patch was working fine and everything but for some reason it decided to stop reading my micro sd. Im not sure if its my micro sd as it was working just fine prior to the patch and I have formatted it 3 times already trying to get this to work but it just cant seem to load the micro sd when it has a lot of memory stored on it. It will load the sd fine if theres absolutely nothing on it, but if I put my music back in it will crash the phone and cause bootloops until I take out the battery and sd to restart it.
It also seems to only happen when mounting the storage on the sd because when I transfer the music from the sd card via the phone and the usb cable it doesnt restart and it loads everything on the card just fine. But once I restart the phone it will work for a couple of minutes and then reboot again.
Has anyone tried Bluetooth with stereo speakers or headsets? (Not mono)
Is this meant to suggest that maybe music will transmit in stereo and just not mono? If anybody can confirm I will just buy my neice a stereo BT speaker to replace her mono BT speaker that won't work with this ROM and call it a day...
Here is the speaker that she has tested this on:Android by default doesn't support music through mono earpieces or speakers but there is an app on the market place to reroute all sounds onto the Bluetooth earpiece if you want to go that route but it may not sound as good. I'm still not sure if stereo bluetooth headsets or speakers work since I don't own either and anyone hasn't said anything if it works or not. Hope this helpshttps://play.google.com/store/apps/details?id=com.maxistar.monobluetoothfree
http://www.walmart.com/ip/Jam-Bluetooth-Speaker/22136933
I assume it is mono, as there is only one speaker, but the phone did transmit music to it automatically with the stock rom, and will not with any of the newer custom roms, so it doesn't seem like an app should be needed. Of course I will try the app next time I see her, though. Thanks for looking into this.
Anyone get bluetooth stereo working? I'm still running stock and am concerned about a rollback... With that I think I'm GTG.
Funny this topic has come up recently. I just received a "Pyle" rugged bluetooth speaker as a gift this weekend. I was able to pair it with my elite, but only the track controls worked, the sound wouldn't. Just to test, I was able to get my wife's iPhone and another android phone to run it.
Something is up with the bluetooth sound on this rom.
R.
It is here Dev-Host - The Ultimate Free File Hosting / File Sharing ServiceDoes anyone have a link to the 10/21 build I think that was the date I accidentally deleted my backup.and that build ran the smoothest on my phone thanks
