Root [ROM][BETA][4.1.2]"L" Awe V2.5 Final[Works with stock device]
Y do u need an image of it if u dont mind me asking??
Well, I use this program called Link2SD (Plus Version), and it stores applications on the Micro SD card using a primary ext 4 file system. I wanted to repartition the SD card, and I did. The problem is that I can not get the files back that are on the empty space of the HD. I forget what that empty space is called. It starts with a U. Anyways, I want to be able to back up the whole MicroSD card. The 2 different file systems on there are FAT32 and ext4. I'm basically trying to figure out how to back-up both partitions and then being able to retrieve them in case I want to save/use that data again. It sure would have been nice to have the ability to recopy that data back on to the SD card after deleting and re sizing the partitions on the MicroSD card.
Ok y not just do this??
I try to install this rom, my zte n800
It presents encryption error
try to encourage this rom to test whether served to fix the error but when installing the ROM, near the end of the process fails
set_perm: some failed Changes
E: Error executing binary updater in zip / sdcard
HELP ME TO SOLVE THIS ERROR ENCRYPTION
AWE ZTE N800 (VIRGIN MOBILE)
I've been having some random reboots with this ROM. Is there anything I can do to address or further diagnose this issue? Or is there another ROM that people would recommend switching to? I'm not blaming the ROM - it's very possible that I screwed something up!
Some times certian aps will cause it and if got the cpu clocked it do same thing i was using the tesla rom no reboots
THIS MAN IS A ****ING LEGEND!!!!!!!!! Thank you on so many different levels as I have been unable to find CWM recovery and you have managed to make something that can flash twrp onto this device still. Thanks a million and have a great day as I currently am!
