Root [ROM][BETA][4.1.2]"L" Awe V2.5 Final[Works with stock device]
So ur not rooted but u do have twrp
Neither... I had obtained temporary root using Kingroot and running benchmark with other background apps to bog the system down. But after using the twrp app and all that, soon as I actually rebooted into recovery to attempt to flash a rom, the phone went crazy. Froze for a while then turned off and on few times uprooting itself.
No u don't use king root
Ok I seem to be in need of some help here . I've never flashed a rom to a phone before and have only done it once to tablet so bare with me I'm a noob . I've ben trying for 3 hours now to install this rom Following the directions to a T with no luck I get as far as
6: In command window type "fastboot boot twrp.img" without quotes. Your phone will turn off and you will be greeted with twrp recovery
Use screen to navigate the menu. swipe to make your selection
But nothing ever loads cmd window just says waiting for device what am I doing wrong here ?
Hi
I remember another having this issue. It may be the USB port. Consider switching to another computer to try the process. A file has been attached. Also, here's a thread that you may find useful.
http://androidforums.com/threads/still-cannot-root-zte-awe-after-several-methods.887418/
Hi
It may be the USB port, as mentioned. You also may need to install a proper ADB driver in Windows to push root through ADB. Windows uses different drivers to connect to your device and to connect over ADB.
Also as mentioned, it may be easier to try a one click exploit method such as King Root.
On a side note if anyone familiar with lg devices would want to help im try to unlock the bootloader of the lg sunset [l33l] [c50 base device] if anyone is interested in helping
You know guys, I lost a WHOLE bunch of apk files, including the Google Play Store. Yeah, so I download the apk file, for Play Store, and it doesn't want to install! Ugh what would you do, haha ( :
