Holy Shit! Monster you are the man! This worked and my phone is back working again. The only thing is that it now says sprint instead of boost. Im wondering if I should use your rom or playful gods rom now.
Does this rom include the scripts that were mentioned in the other thread or do I need to re-do them?
Thanks again monster. I got yours up and running and after a stressful 24 hours I couldnt be happier. Donate link?
Heres your link: LINK
Are you sure that backup was rooted?
If so, it didn't stick. But thank you so much for the effort. Guess I'll just stick with the stock till I find a pc
update noticed that when i end calls the phone freezes and i have to do a battery
pull
My bad I can send you a new one this afternoon
I had a problem, I flashed the ROM no problem but I can't get the hotfix to work. I'm using 1.1 and can't flash the hotfix for 1.1. I get an installation aborted error message.
I installed V. 1.1 and it has SuperUser and CMW installed already is this normal?
EDIT: Would I be able to use this theme: [THEME] ◄ORIGINAL ICE CREAM SANDWICH THEME v5.0► *ICS ANIM*KI4-KJ2-KJ3* [17.11.2011] - xda-developers
with my phone?
Is there a way to get my old Music player back since the beats player is giving me major problems when I try to play it through bluetooth headphones.
Just uninstall it then download it from market
Didn't help I still get random disconnects that I didn't get before flashing it worked perfectly with the stock music app. I just want to use my BT Headphones and I'm stumped.
It is rooted but the binary is out of date. reinstall superuser
TO OTHERS:
hot_fix1 has been fixed, there are some precautions: read the 2nd post
Thanks man, using blue bootani and this
bluetooth is having small issues right now, im working on that. This rom is still beta, which means not everything works/may not work/does work/. Until i can figure out what bluetooth is having a delay you may have to listen to music the old fashioned way, with a cord![]()
How did u change the app pictures like that?
