How do you change the carrier name in cm7?
I decompiled the framework-res.apk and went to to strings.xml file to change the name, but i could not find the line:
<string name="roamingText1">Virgin Mobile</string>
that's how i changed it in my last rom. can someone tell me how to change it please? and would i need to reflash the whole cm7 file again after i make the changes to the framework-res.apk? (im a noob as u can tell by now) thanks
This is what mine looks like. Pretty cool rom. I'm digging it.
Where'd you get your wallpaper from?
On this ROM it seems like the tilt sensor is messed up. I was playing a game called Hyper Jump, it worked fine on Tickerguys CM7 0.8 but now on this ROM the tilt lags a good bit. Anyone else experience this?
Somebody more knowledgeable may know better, but I kinda wonder if maybe the accelerometer issues stem from the memory management. TG's CM7 has memory management set to be more aggressive, but this one resets it to the default. So those of you who are having problems may want to try tweaking your minfree settings and see if that helps.
I was digging around for the CRT animation. Somewhat unrelated, but can someone make a stock rom that includes it? I don't want to install CM7 just for this.
the hotspots always cuts of when trying to tether to another android on cynogenmod 0.8 will this make the hotspots more steady? and active???
Has anyone tried car home?
Even after GPS locked, it says "Searching GPS"
FYI. Updated from CM7 vB.08
sounds like an app problem, does it behave the same with navigation? or another app that tries to get GPS lock?
I also thought it was an app problem, but I couldn't reinstall car home, so I reinstalled Map.
Map locks it and GPS status Locks it.
As for the navigation, right after reboot, have to try couple of times to get it work, or launch it within map works but not always.
Will the flash rom fix it? or is there any way I can reinstall car home?
New 12-28 build uploaded, check post #1 & #2 for link & changelog.
With the latest update, do you recommend using the Interactive governor over SavagedZen or InteractiveX?
Also, in your opinion, do you think that Undervolting works? I've read where some people say it doesn't really work and actually hurts performance more than it saves on battery, and I've read others swear by it!
