Root [ROM] CyanogenMod 10 for the LG Motion 4G LGMS770 (l0)
can you explain why/what is used?? And whats not needed in my builds.
Point of this thread was to differentiate issues from Bobs and mine. ;)
The zip includes:
Front Camera Fix
GPS Fix
Sound/ Call Volume Fix
MMS Fix
Front Camera, Sound/ Call, and MMS works on your ROM already.
Got GPS working after flashing allfixescm10bobz.zip
I can't remember if this is all of them so someone add on to the list :)
Upvote 0
The zip includes:
Front Camera Fix
GPS Fix
MMS Fix
GPS doesn't work on your ROM and bobz fix doesn't work on your ROM either (at least for me
It doesn't)
The BobZ GPS fix is already included in PG's build.
Upvote 0
The all in one zip from above fixed my GPS on Pgs. I can lock on perfectly with wifi on or off. Now all that's left for me is the random backlight issue that happens once a day or so. I seemed to noticed it only happened to me when brightness was on the highest setting. Never happens if I keep it at half brightness and keep it that way.
Upvote 0
BEST TECH IN 2023
Smartphones
