Flashed last night and all seems good.![]()
Quick question: What does it mean if I have the earlier version of CM7 for Hero, and I try to flash this one and it says "Installation Aborted?". Or better yet, WHY wont the installation finish?
Can I flash this using CWR v2.5.0.1?
any screen shots?? how different is it from Aosp GB??
I'm about to go from AOSP Froyo to CM7.
On another post I saw a note for those using the latest version of recovery. It has a link to aospCWMod-HC-20110326.img
What do I do with that? My version of recovery is 2.5.0.7
Also, what overclocking should I use?
First off it is not required to update your recovery to flash cm7 but if you want to you can. The easiest way I know how to flash it is through terminal emulator.
1. Download the the .img file to sd card and put on the root of the sd card(not in any folders)
2. Open terminal emulator and type: (hit enter at end of each line )
su
flash_image recovery /sdcard/name-of-recovery.img
*****where name of recovery is put the exact name of the file as it is on your sd card probably, aospCWMod-HC-20110326.img
Then you should be able to reboot to recovery and it will be the new recovery image you just flashed.
As for overclocking it more of a trial and error to see what your phone likes the best. Some can run awesome at 768 and some find it gives them random reboots. Play around and see what works best for you.
When I tried CM7 I experienced alot of lag. It just felt very unstable. The notification bar twitching like does was a big turn off. Anyone else experience and of this?
I disagree on the lag. Been running ASOPGB since January and decided to try CM7 this weekend while waiting for the next ASOP drop. CM7RC4 is running outstanding for me. I honestly cannot tell the difference between this rom and the 3/26 asop release.
Anybody know if I can use the 3/7/11 GAPPS on 6.1? Having trouble downloading & updating apps again
I plan on it I just wanna make sure all my apps are up to date before I backup & flash. I'd hate to flash to GB, need to flash back & have the same problems with my appsNo I'm pretty sure the 3/7/11 Gapps are specifically for gingerbread. You should just flash a gb rom they are silky smooth.
