PlayfulGod
Extreme Android User
Here ya go folks, a proper port of CM7 for the LG Optimus M. Donations are greatly appreciated, but are not required!!
- Author: PlayfulGod
- Developers: PlayfulGod and BobZhome
- Current Version: 10182011
- Description: CM7 port for the LG Optimus M. Well, let's be honest. Unless you're living under a rock, you probably know what Android 2.3.5 (Gingerbread) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: http://www.cyanogenmod.com
People I wish to thank
- BobZhome - for his assistance and forked Repo
- inferiorhumanorgans - for his awesome coded repo for the LG Optimus line. Sure made it easier to port CM7 to the OC.
- zefie - for the original port & repo from the thunderg to thunderc.
- aospbot - I think he had a hand in the original porting somewhere, so want to throw him some credit too.
- sillyputtyddd - for his testing, feedback, providing needed file, info, and insight.
- chris9983 - for his testing, feedback, and providing needed info from the OC.
- Woof, gregcapps - for testing and feedback.
- thevisitor83 - for testing the MS690 builds and providing the needed files.
- isaacj87 - for his continued support and advice.
- koush - for his kickass recovery.
- CyanogenMod - should I say more? Thanks for the best ROM out for our Android devices.
- The Android Community as a whole for supporting me while I do stuff I enjoy.
- 08172011
- sync with CM Repos (2.3.5)
- 08182011
- initial build
- Fixed Network GPS
- Fixed launcher/added launcher pro
- 08192011-build 1
- Changes to try to fix bluetooth
- Changes to try to fix GPS Satellite
- Fix for Roaming on lock screen
- attempt to fix mms
- added BobZhome oc'd kernel
- 08192011-build 2
- Replace kernel with one I compiled
- 08192011-build 2
- 08202011-build 1
- Applied some more MMS fixes for CricKet
- Replaced kernel with stock kernel for now
- build 2
- MMS fix
- GPS fix
- build 2
- 08212011 build1
- Synced with BobZhome's repo
- trying a different bluetooth driver
- Build 2
- Switch back to my repo
- Stock kernel still used
- Applied GPS fixes
- Applied MMS fixes
- Build 2
- 08292011
- Bluetooth fixed
- Custom bootanimation added back
- ADW used from CM src
- 08302011
- Compiled build for MS690
- Initial testing
- Initial release
- 08292011
- Bluetooth fixed
- 09032011
- Plague Overclocked kernel - by PlayfulGod, thanks to isaacj87, reppard, and BobZhome for their assistance. Cpu scaling added for 672, 691, 710, 729, 748, 768, 787, and 806, and beyond for those brave and lucky souls .
- cpufreq for CM7 cpu setting
- TronDroid added to CMWallpapers and as default wallpaper.
- Custom initlogo (bootsplash)
- camera fixed
- 09072011
- Release with all previous mentioned.
- 09082011
- reverted the screen fix
- bootsound
- 09092011
- kernel tweaks, default cpu speed set @600Mhz, smartass and interactive governors added.
- screen lag fixed - Thanks to BobZhome for finding that.
- Custom themes added, Honeycomb 3D 3dicon and Rovers Cyan
- DT's a2sd
- 09112011
- Plague Kernel updated, now max overclock of 921Mhz
- ext4 support
- swap support
- max oc of 921Mhz
- smartass governor
- interactive governor
- Inverted camera fixed - download and flash kernel update.
- 09192011
- Synced with CM repo
- Plague kernel updated with smartass2 governor
- Install in CWM like any other ROM.
Links
Download links and more details
Want to Show your Appreciation?
- Donate
- Any and All donations are appreciated: Official Donate link
OP should be updated.
