I really appreciate the fact that you took the time to help me. Though, I only trust official releases from the original software creators. Just a rule of thumbs for me. I did do exactly what you did, I deleted the first line of code in the updater script before I even posted here and the flash just gets canceled.![]()
Yes, I'm saying your fix on the updater script was the same way I attempted to fix it. So with the first line of code with the board check, it causes a error in the check process. Then if you delete that problematic line of code, it just immediately aborts the flash process.
:ridinghorse:
Edit - You know what's strange? Your updater script fix was the same as mine but yours worked and mine didn't. Carbon copy match. What else did you change besides the first line of code in the original updater script? Thank you very much, my friend.
I have this rom on my optimus m. I noticed at the playfullgod site there is a download for a kernel Plague v2. Is this newer than the one that comes with the rom?
