Try downloading rom toolbox from the market and go to where it says build.prop tweaks and move the bar that says lcd density or density until the value is either 120 or 110 and save the changes. The screen should fit after a reboot.guys how would i go about switching the res on the rom to fit on my m835 screen.. im talking about the ascend rom thanks
I haven't run this rom in a while so i can't give you any advice for it but i can tell you that the ascend 091311 rom works near perfectly on my M835. The only work is to change the lcd density and replace the keyboard, other than that it works fine other than occasional reboots after it settles.and also how do i get wifi working
I'm stuck on the Huawei Boot screen. not sure whats up....
worked for me
So has the Wi-Fi issue been fixed with CM7 for the m835 yet? I just bought one of these little junkers to play around with. If it still has Wi-fi problems, could I just root it and use TBPro to remove the bloatware, keeping the stock ROM on it? LOL, I would ask about CM6 for this phone, but I've never seen it mentioned while searching through AF![]()
Hey PG, thanks for all the tutorials and help with this phone. I whave the same phone from metropcs: Huawei Ascend M835. I used "SuperOneClick" method to root it. But i noticed that. IDK how to get the drivers for my computer [i'm running windows 7 ultimate x64 bit] and i obviously have the USB drivers installed, but in device manager i do not have a "DBADAPTER Interface)" mentioned in the ((3G forM835)) 's method.....working on the ascend 2 too![]()
can anybody including you, can help me find the drivers soon as in ASAP, i've must've been looking in the wrong places. thanks for the effort in helping me...... plus i wanna obtain a better ROOTED ROM, because i also have to use a "better keyboard" app just to be able to type/txt on my phone because for some reason i lost my non-swype and swpe keyboard.apks that came with the phone
okay, im a bot new to the android scene, i have an huawei m835, had it about 3 months rooted it the 1st week i had it. now thinking about installing cm7 but i read through the entire thread and got lost. does anyone have a full tutorial with updated links and updated roms that have no wifi problems? i want to install cm7 but idk if the 1st page post is the most up to date version because there is no indication if it is. PG i thank you and everyone who has helped you and that you helped to make a port for the huawei m835 you guys did some great work. not to just install it and try it for myself...and thank to whoever replies
I've tried flashing various GApp zips to my phone, and none seem to work, or even show up. I also tried to flash a fresh CM6 in tandem with said GApps, and nothing.@TBTE: Do you know of any sites where I can download the GApps for my M835? I'm running the CM6 port for the Ascend. Works great, but I need a market connectionI've tried flashing various GApp zips to my phone, and none seem to work, or even show up. I also tried to flash a fresh CM6 in tandem with said GApps, and nothing.
TBTE thanx for the reply, didnt think anyone was still looking through this thread.
If i was going to install the cm7 rom, how would i do it?
and step by step process i need to know about, and can i go back to my stock rom if i dont like the cm7 rom/
Well if you have don't have Root (I'm being so stupid right now) you shouldn't be here.
If you do have root (Which you probably do) and you are running Froyo (Which you probably are) you need to download the ROM from PG's Wiki page, then when done with that go to android market and install ROM Manager.
Open up ROM Manager and get pass the impassable ADS OF DEATH, and it should ask you for you to install a clockrecovery and it should show up as U8150 (This is basically the m835 with a different name), install it.
Now hook the USB cord up to your computer (or if you downloaded the ROM from your phone skip this skip), enable USB Mode, and drag the ROM (in the .zip form) into the root of your SD Card.
Put your phone out of USB Mode, and go back to ROM Manager, click Install ROM from SD Card, It should open up a browser with your SD Card contents on it, go down to cm7 or whatever the ROM name was. and click install.
When this is clicked it will ask you if you want to:
*Backup Existing ROM
*Wipe Data and Cache
*Wipe Dalvik Cache
Click all three, you need a backup of Froyo just in case something happens or you just want to go back to it.
It should ask you if you are sure you want to reboot in recovery and install the ROM, say yes.
It should reboot in recovery and automatically start going to work in recovery, towards the end of the operation you should get an error saying *sd-ext was not found, skipping backup of this.* This is normal and you shall ignore the living hell out of it.
After getting done with the backup it should start to actually install the ROM, you should get the same error about the sd-ext, once again this is normal.
After that your ROM should finish installing and it should reboot with your new ROM!!!!!!
The new ROM is going to take about 2 or 3 minutes to boot so don't worry.
Just set it up from there~
Also if you need gapps just holla @ me.
Alright, TBTE thanx for the step by step, can i get the gapps and do you know where i can get the froyo 2.2.2 froyo rom? incase i want to go back to it
you need the gapps for cm6 kind sir?
http://cmw.22aaf3.com/gapps/gapps-mdpi-tiny-20101020-signed.zip
go to recovery and install zip from sd card blah blah blah blah
The gapps for froyo will be kept in the backup for you xXDanTheManXx.
2001mikeh, I they haven't made one that has the Wifi working.
I however am working on one for this phone.
@xXDanTheManXx I cannot get the Ascend ROM or the clockworkmod for it on my phone, it just gets stuck on boot, but not worried about it. If you can help me about that i would be much happier.
as for the gapps, i ment the gapps for the cm7 port, if they are the same then nevermind
Dont know a whole lot about roms or anything, but id be glad to help,
btw everytime i try to back up my stock rom, my phone reboots and hangs on the huawei logo. any ideas?
*EDIT* nvm,i was able to get into the recovery menu and make a back up of my stock rom.
TBTE pm me and ill give u my email, so i can help you with whatever it is you need help with.
anyways you should flash the ascend roms..they work better..ive flashed the cm6 and cm7 ascend rom on the m835..let me know if you help
epsi:Ok I am looking for a rom. I have cm 7.2 from playful god but no wifi and camera. I tried the ascend rom and it wont install can someone post the inks to a cm rom that does work. ty
