Root [ROM] Deck's ReLoaded | LOTK | Ver 500 RLS
WOW! ... was my initial expression for this rom! It is awesome! I've been playing around with a bunch of great roms but this one's like discovering another universe. I've never seen a rom with an installer that lets you customize what you want to install. Is that what the Aroma thing is? Anyway, it's beyond awesome, I wish all roms had that feature. Plus it's very smooth, quick, and responsive. This one just might have to hang around on my phone for awhile.
Awesome awesome awesome work on this one devs! Keep it up! :D
big thanks. yes that's aroma and it will be getting a nice organizational facelift in our next update. enjoy this one, you've got time. I also recommend that you use the Mason .15rc4 kernel that wasn't available at the time. both are sbc, one has fso, the other doesn't.
sbc fso
http://db.tt/oJMYvYFq
sbc
http://db.tt/8xbV1iko
for a little bit of jellybean wallpaper goodness go here:
http://db.tt/EhBUZeEL
have fun.
ropodope
If I load the apps through Aroma will they still pick up my profiles and other personal stuff, Go Launcher for example.
Do you mean, how you set up Go Launcher now the way you like it, after rom flash will it come back the same way? I dont think so, as you wipe before a flash but perhaps backing up apps with data with TB before wipe/flash, then restoring app data with TB after rom flash will work.
But if coming from a sense rom to AOSP rom, app data restore from TB will not go over so well.
Am I following your question correctly?:)
Kind of. If I install apps through Aroma instead of TB, will my phone still recognize my data. Like in Go Launcher, I have some profiles saved, I'm wondering if they will still be available or do I start from scratch.
I have an old profile that goes perfect with this ROM. Lockscreen:
Desktop:
Sorry for the late response, for some reason website didn't load on my computer, but yes, forgot about GoLauncher saving settings to sd card.
Thanks brianvillage!
Right, it will be compatible but you'll have to manually restore your profile. Any data that is not backed up will be wiped.
Ok, I've seen talk on this issue but, not sure I ever saw a fix. On my first reboot I will be missing apps that will reappear on 2nd reboot, I can live with this. But, I have to restore any widgets which is kind of a pain. I changed Busy box to 19.4 per a post on XDA, didn't help me. The only quick fix now is to restore a Nand every time I have to reboot. Any advice? I do have a partitioned 16G class 10 card, no cache to ext. and only ext 3 in use.
Yah, its the issue with the class 10 card, like mine.
I work around that like this.
Boot into recovery,
clear cache and dalvik
fix permissions
clear cache and dalvik again.
repair ext (in partition sd card option)
reboot.
let phone sit until booted up and screen goes off by itself
Takes about 10 minutes for my phone to do so.
Voila, all widgets/apps intact.:D
Boot into recovery,
fix permissions
reboot.
Yeah I have done something similar but still see the same issues sometimes. I usually run the commands in terminal emulator
su
a2sd repair
a2sd reinstall
Honestly lately I've moved away from a2sd. I think it helps with the speed of the rom with everything running off internal memory rather than sd. But I don't really need a ton of apps, so if I control my hoarding and do some other basic practices (like running facebook from a browser bookmark instead of the space consuming app) then I can get by.
you should be using busybox 1.1.6 not 1.9.4.
ropodope
ropodope
Ok, I always thought updating to the latest anything is always the way to go. I have version 1.20.2 on my phone. Will this cause problems? can I just reinstall the one you mentioned over what I have or do I need to do some type of uninstall first?
no just install over it.
ropodope
