There are different themes that came with the rom, each of which I believe will change your status bar.Love the ROM ans Go Launcher. Is there a way to theme the status/notifications bar?
Use the Theme Chooser app that comes with the rom
Worked great. Was able to change the status bar without changing the go theme. Thanks.There are different themes that came with the rom, each of which I believe will change your status bar.
Use the Theme Chooser app that comes with the rom![]()
I think menu/settings/ advanced settings/interface/notification power widgetOne other thing, is there a way to change the options on the pulldown bar with this theme? Such as whether it shows 4g, wifi, etc...
You're all over it!I think menu/settings/ advanced settings/interface/notification power widget
I love this rom, not much of a flash-a-holic as some are, I like to find a rom and run with it if I like it....You're all over it!
Yeah, I found some but none seemed to change the darn status bar icons. The one's that were built in do, and applying it only changes the status bar. I guess because it's at default, and the other items are customized. I'm not sure.There are tons of themes. Search for cm7 theme on the play store.
Right, I'm not much on flashing a lot these days as well. It was time for a change though and I'm glad I found this.I love this rom, not much of a flash-a-holic as some are, I like to find a rom and run with it if I like it....
This rom is slated for an update sometime......keeping my eye out for that and PapaSmurfs Cm9 rom also...I may try that one when updated soon also...who knows?![]()
I haven't heard anything...all I know is Jamie had some life stuff that needed attention, and that's what takes precedent (sp?) now.ETA or update on what is crackin with the new release?
he is ok and when he's ready we will be excited to get back on the update.damn this is a popular thread LoL!! I hope that the Jamie person (i only word it that way due to the androgynous nature of the name Jamie) is ok!! The update can totally wait in lieu of fam stuff!!!
I think I'm gonna mess myself when the update hitsI wasn't aware of the personal issues popping off with one of the rom dev's. Of course that would take priority and I hope all is well. I only asked initially because the current rom is so good I'd like to see the new one before I move over to the S3.![]()
I think I'm gonna mess myself when the update hits![]()
I did see discussion of that over on XDA....yes it is a tower issue.Has anybody else had problems randomly loosing data connection with this ROM? Maybe its Sprint, I know they are in my area working on LTE and I've been having issues with MMS(pics) not always coming through. Just thought I'd ask.
Ropodope had that prob.(among others)...then it was fine just after a couple weeks....![]()
