No eta when this is gonna be done buts it gonna be done right
Can one of you jack the lockscreen for me while you're toying around with the update? Thats all I want![]()
Won't let me install on Spz0's OA2.3, oh well.
I guess I'll have to wait for this rom because my phone won't root for pickles
ur trying to install the default launcher.
lockscreen is located within the android framework, so its a little tricky to extract it.
I _may_ port the lockscreen over as an addon, but at this point I dont think I'll have it native in OAx.x.
We'll see tho.![]()
Ok I ma upload the metropcs 2.3.6 rom don't flash it! It won't flash I delete the binary and update script so a noobb accident won't accour
I need someone to put the update binary and the update script so it can work thank you
Idk what I am doing wrong
"Metropcs2.3.6 deodox_2.zip" - Metropcs2.3.6 deodox_2.zip - 4shared.com - online file sharing and storage - download
You need to do some good reading up on updater-scripts and update-binary files. Google holds the key.And when learning the ropes of proper cwm zip formation and edify/ammend scripting, it helps to look at a few other developers scripts to read and understand the process.
Good Luck!
I use this program to create my 4G icons and when I use it on the rom It gives me erorr status 6 then I re wrote it and change it and it gives me missing part?? Lol I look at it again when I come back from the water park
rofl! So true m8.forget AMEND, FORGET IT!!
well if hes on windows yea, if on linux gedit or nano works greatrofl! So true m8.But he should learn it anyhow, just to know the difference, and to better understand the improvements to edify.
He needs to also be using Notepad++, for everything.
I think he's running into EOL issues using Notepad. Need to convert that shiyt to unix EOL using notepad++.
And def. yes, feel free to snag my updater-script and update-binary for use. The binary should be compatible with 5027 and 5028.
Good luck!
well if hes on windows yea, if on linux gedit or nano works great![]()
Pm me the zip and ill help. Got a new laptop today!
