MizzouBrent
Android Expert
Tried this yesterday and it is blazing fast and nostalgic. I do find myself missing quick settings from the newer sense roms though.
Ok guys i have updated my op on xda,with ELITE Series Resurrected 1.1 tweaked and a flashlight app added.Enjoy.
Your very welcome,bro.I'm starting a new project "Revolation Rom",if anyones interested in beta testing for me,let me know in my pm,i'm only excepting 2 testers at the time,if anyones interested.Actually i have a beta ready now.I have afriend,Bill Bowers creating a theme for it as i type and i have added a few tweaks and the More lionfish kernel,its sense 1.0.ohhhhhh sweet. gonna download this now and i will update the op in a sec. thanx again diablo67
I only post on here an XDA,because your the only 2 forums that rule.Well, It's appreciated that you do. So thank you very much.
Naters
, does this ROM natively have the ability to partition the SD card and use it as internal memory?
Thanks in advance!
Thanks, I've already read that, and the very helpful posts by novox77 and akazabam, and taken care of the partitioning.You need to partition your card first. The write up in the How to Root threa is really good. There are some other write up there also.
Once your card is partitoned I don't know if this Rom will automatically move them for you. You may need to us A2SD to do it.
My trouble lies with what to do now. From what I understand, I need a ROM that either has A2sd built in, or is at least compatible with Darktremor A2sd. So I need to know if this ROM qualifies... or if I'm mistaken about the nest step.
Yes it does support Apps2sd.Thanks, I've already read that, and the very helpful posts by novox77 and akazabam, and taken care of the partitioning.
im just surprised to see that its not built upon the ics rom... whatever tho LoL just as long as its not a rehash of es3 i guess. Is it a fresh build?
flash back. i like that. lolhi...oh my sort of a flash back.lol..will have to drive this one soon too.
I've tried flashing Darktremor 5 times now, using files downloaded from two locations, without success. Does anyone have any suggestions?
It runs that list of checkboxes and only stars the final (finished) box. It never confirms mounting or anything else.I have bot tried it yet on this Rom, but what exactly happenswhen you flash it?
I'm running darktremors apps2sd and it works fine,make sure you dont have a corrupted file,redownload it and try it again.It runs that list of checkboxes and only stars the final (finished) box. It never confirms mounting or anything else.
I have downloaded a couple times from two different sources. Are you using Beta 4?I'm running darktremors apps2sd and it works fine,make sure you dont have a corrupted file,redownload it and try it again.
