bilgerryan
yea that's what i have been doing is launched it in gallery . Yes i called boost and got my MSL .
I use MX Player, it's better than the stock one IMO
Could someone rewrite the mms fix for TW roms
Loving 4.0... can I flash 3minit framework over 4.0?
Can xthemer or hkthemer work with project x roms? tried with 3.9 and would just get boot loops or systemui fcs. is it because of different names for images?
Well I will will be moving on to the S3 in the next few days, it's been fun
I loved your ROMs on the E4GT and I await the arrival of you first ROMs on the S3,i just got one myself. Check out RadioShack, picked up mine for $249.99 + tax
Too latein my gusto, I let it happen, ah well, I don't really care about warranty anyway lol
Congrats on your move to the S3, and for the work you have done for the E4GT. Hopefully I will be migrating to the S3. I am still happy on my S2 until prices drop some..![]()
anyone have a link to different CPU schedule for Oc and UV
I use the voltage control app to adjust that. It works well for me. CPU Master Pro works well also. Both are available on the play store, and work with the Agat kernel that supports OC and UV.
OK guys been running this for a few days now and really liking it a lot, very easy to install, its OCed, runs very sweet.............
Thanks again bilgerryan for another fantastic build sir......
Project X 3.9
[ROM][GB27] Project X v3.9 {Team Rejectz}(Updated 1/5/14) - Page 695 - xda-developers
[ROM][GB27] Project X v3.6 {Team Rejectz}(Updated 9/25/13)![]()
Knowledge is power, please read all 4 posts of the OP because this is where you will be referred if you ask something that is located here. Make it easier on yourself and everybody else and take the ten minutes to read and understand what you are doing so you don't brick.![]()
This is a GB27 DeOdex TouchWiz ROM themed like the S4 with all the goodies of the Xperia Z, there are very few tweaks included so you can use the ones you would like to. (ComaDose, Exit_Only's, kobridge's, and almost any other tweaks will work with this)
-TBSGS4 GB27 base-here
-Agat64's Source Kernel v1.3-here- under/overclocking and undervolting supported
-Modified Xperia Z Laucher
-Tons of Launcher Options
-Sony Walkman app
-Google Lyrics Walkman Extension
-AC!D Audio-thanks Team AC!D
-Bravia 2 Engine
-Sony Xperia Social Engine
-Sony Xperia Z Ringtones
-Sony Xperia Z Notifications
-Sony Xperia Z Alarms
-Sony Xperia Z UI Sounds
-Galaxy Note 2 Gallery (SecGallery.apk)
-Sony Album
-Picasa Album Extension
-Sony Facebook Integration (plugins & extensions)
-Twitter Share Plugin
-Sony Movies
-Sony Social Life
-Sony X4 Video Player
-Audio FX Widget
-Xperia Z & Xperia T Icon Packs (Laucher Settings/Appearance/Icon Pack)***support for most icon packs on the Play Store and changing icons on the homescreen to any icons
-Xperia Car app
-SMS Enhancer- SMS Pop-Ups like on 4.2.2
-erikalin's Stock App (a lot of stock stuff was removed)-here
-AIO v4.0-here
***Note- 3Minit Settings is a separate download with AIOv4.0+ as per request by gharrington- located in v2.0 OP***
-Tabbed System Settings
-AutoHDR res overlay-Thanks Rizal Lovins
-Sony Clock Widgets
-HTC Tile Clock/Sense 5 Weather Widget
-Sony Wave Live Wallpaper
-Sony On/Off Tools
-Sony Photo Slideshow
-Sony Notes and Widget
-Sony Top Contacts Widget
-Sony Weather Widget
-Xposed Framework Installer
-SGS4 Themed Contacts, Phone Dialer, and In-Call Widget
-SGS4 Themed TouchWiz Music Player
-Samsung Link (AllShare)
-Hacked Sprint Hotspot with 4G-thanks crawrj-here
-Ripple/Ink Effect Lockscreen
-SGS4 Calculator
-Samsung My Files
-232 Fonts including Sony Sketch (System Settings/Display/Font Style)
-All the TouchWiz features you know and love (Motion, TW Email, TW Browser, TW Music Player, TW SMS, etc.)
-Blazing Fast and Efficient
-Flash and find out what else
First time on Jelly Bean TouchWiz? You MUST do a one-click Odin of TouchWiz 4.1.2 on your phone first to correctly partition it.
NEWBIES, STOP AND READ THIS FIRST!!! http://forum.xda-developers.com/show...4#post35539014
1. Download full ROM, verify MD5 checksum and copy to phone SD storage.
2. Download and copy Jellybean X2 Format utility to SD storage: http://forum.xda-developers.com/show....php?t=2077277
3. Install EL26 (Chris41G) kernel or EL29 Directboot kernel.
They can be found here: http://forum.xda-developers.com/show....php?t=1662295
( Look for: GB - Stock EL26 Repacked Kernel or GB - Direct Boot CWM )
Note: For success, EL26 & EL29 kernels are recommended for flashing this rom!
4. Reboot into recovery, flash JB X2 Format then the ROM. You may flash a JB modem at this point if you like (required to run JB), but no other mods until ROM has fully booted the first time. CLEAN FLASH ONLY! (Don't even ask cuz I'll flip on you for not reading the OP)
***Note- EL29 cannot flash modems
5. Let ROM boot fully and settle for a couple of minutes during the initial boot. (It will take around 10 minutes)
6. Setup, then try out the features and debloat to your liking. It's recommended for performance's sake.
SCREENSHOTS
I have my wife's old S2 and I rooted it and installed the EL26 (Chris41G) kernel, flashed JBX2, flashed project x 4.0 and all looks great. The problem is the phone was not activated when I did all this and now it won't activate or communicate with the network (or that's my description of things). Any idea of what I can do to fix this? Thanks in advance.
I flashed 3.9, if that makes a differnce? Everything else seems to work fine.
Still can't send pics!!![]()
