Do you have a better place to upload those roms? It should not take over an hour to download them.
I followed the instructions to locate the ROM, it works well. However, I still encounter "insufficient space" issue after installing a couple of apps although I assumed this ROM with an link2sd'ed ext2 partition on SD card would solve the "insufficient space" issues. What else should I do to work around the space issue? Thank.
Hi, I am using the ROM from the other guy (ahmrad or something).
How do I change the shortcut buttons on the keybaord to work as arrow keys?
which files do I modify in the zip?
You can't just go modifying the contents of the zip file, but I got the instructions for remapping the shortcut keys to arrow keys from here:
Some useful hacks for the Samsung Gravity Smart Ben Chadwick - writer, etc
hi. thanks for the info..anyway my phone now only picks up edge signal..how do i get it to pickup 3G? i have tried disabling "2gonly"but still.just get the edge network. all networks in my country support 3g
If you are using Arhtard's rom, I would ask you to direct further replies to the thread for his rom. But I would try switching your SIM with a known-good phone and see if the problem follows the SIM or not. Neither my nor Arhtard's ROM makes any changes to the kernel, so your connectivity should be exactly the same as stock.
